60000 mile maintenance.
Old Sep 14, 2009 | 08:38 PM
Black01's Avatar
Hi guys I'm closing to 60k and I'm planning to take my car to the dealership for this maintenance. Question is what do they do? Can this be a DIY or it will be better if I take it to the dealership? How much is the average cost for our GD3's since the mechanic do not have a timing belt to replace?
What should I look for so they don't BS me?
Thanks.
Old Sep 14, 2009 | 08:42 PM
spreadhead's Avatar
You need to do what your maintenance minder tells you to do. Anything else is your dealer ripping you off.
Old Sep 14, 2009 | 08:57 PM
willy65000's Avatar
You may want to have the valves adjusted. Other than that, You can top up fluids and replace the cabin and engine air filters on you own. If you end up needing to top up your coolant, just make sure you buy Honda coolant. I made that mistake and ended up having to flush the system after using the wrong stuff.
Old Sep 17, 2009 | 09:06 PM
Black01's Avatar
Okay thanks for the response. How about the transmission fluid?
Old Sep 17, 2009 | 09:12 PM
secondspassed's Avatar
Personally I'd change the tranny fluid at 60k. Honda recommends it *if* you drive at low speeds on hills regularly, otherwise at 100k or 120k, I don't remember.
Old Nov 22, 2009 | 10:42 AM
Black01's Avatar
Thanks guys. I'm thinking of adjusting the valves myself. I've seen this procedure before done in my previous car and it seems pretty easy but i will still need a DIY guide for the Fit or similar vehicle.
As for the tranny, I drive mostly at high speed around 50-63mph which are for the highways going to work.
Old Feb 25, 2013 | 04:21 PM
So I did some searching and can't find any threads dedicated to the 60k mile service for the GD (outside this one), what exactly do I need to do? I'd rather not take the car to a stealership.
Old Feb 25, 2013 | 04:28 PM
Wafulz's Avatar
i would just change filters tranny filter tranny oil brake oil clutch fluid if stick and for the hell of it coolant and thermostat
Old Feb 25, 2013 | 07:48 PM
Gregg's Avatar
At 68,000 miles on my 08 standard automatic Fit, I just has the oil & filter changed, tires rotated and transmission fluid changed. Total was $138 with all taxes and fees included. That was the b13 service.
Gregg
Old Feb 26, 2013 | 12:17 AM
MTLian's Avatar
2 bottles of transmission fluid should run you about 16$. I would recommend trying the Amsoil synchromesh. I went with the honda brand and was slightly disappointed. Honda coolant is about 20$ for a bottle so you can just drain it and fill her up. Bleeding brakes looks pretty straightforward, I will be doing that along with a valve clearance adjustment this summer.
You can DIY and save hundreds in labor. If you have a mechanic you trust, getting the car checked is not a bad idea. My mechanic must miss me ever since I got my Fit lol
Old Feb 26, 2013 | 12:48 PM
Marrk's Avatar
To hell with the Maintenance Minder. Ditto the dealer.
Do This:
1) Check the valve clearances.
2) Replace engine oil, tranny oil. Not a bad idea to flush and replace coolant and brake fluid.
3) Check brake pads and drums.
4) Replace engine air filter and cabin air filter.
5) Inspect tie rod ends, CV boots and generally have a look at things.
6) Inspect serpentine belt.
7) Replace spark plugs.
8) Rotate tires every 10k miles.
You can do all of this yourself. (Maybe you don't think you can, but you can.)
Others here will say that you don't have to do some of the above. But it's not their car, is it?
Old Feb 26, 2013 | 01:14 PM
MTLian's Avatar
Do This:
Can you elaborate on how you would go about checking the drum brakes? Also, how would you do number five and six?
Old Feb 26, 2013 | 07:05 PM
Gregg's Avatar
Ten or maybe even five years ago, I would have agreed with you. I was really into cars, mostly Chevelles, up until about 10 years ago. But you finally reach an age where doing it yourself is not worth the discomfort afterwards.
Yes, I could have done all of the maintenance myself for maybe $40 out of my pocket, and spent the whole day doing it. You will come to a time in your life where spending the extra $100 is worth it, to have some one else do it.
Gregg
Old Feb 26, 2013 | 09:28 PM
Marrk's Avatar
Drum Brakes: Jack up the rear wheels. Release the parking brake. Remove the wheel. Pull off the drum. Examine the crescent shaped "shoes" for wear. At 60k, you shouldn't need to replace anything, but you could take some compressed air and blow out the brake dust.
Serpentine Belt: It is almost completely obscured by other stuff, but, as best as you can, get your eyes on it. Look for cracks and/or wear. No mystery here. Just obvious stuff.
Replace Spark Plugs: When you have everything off to do the valves, replace the spark plugs with new ones. Gap the new ones first. And, before you start, make sure you have the right size spark plug socket. Use anti-seize on the new spark plugs' threads.
Old Aug 2, 2013 | 11:30 AM
beadbroad's Avatar
THANK YOU. This is what I came here looking for, after calling 4 different places (including 2 dealers) and getting 4 different answers. I had already decided "To hell with the Maintenance Minder. Ditto the dealer," but desperately needed the rest.
Do This:
string3599
17
Aug 25, 2019 10:40 PM
Sonnington
Mar 29, 2018 07:32 PM
ishcm
Jul 9, 2014 03:23 PM
JDMxGE8
13
Mar 20, 2012 02:04 AM
Chairman Kaga
Jan 5, 2010 04:15 PM
