Transmission Fluid Maintenance Minder?
Old Jul 9, 2014 | 12:19 PM
ishcm's Avatar
So I'm driving to work today and the maintenance minder turns on, giving me codes B1 and B5. B1 rotate tires, ok I get that. Need to do that. B5 is the transmission fluid. I'm at 68K and changed the transmission fluid at around 60K.
So I get to work and pop the hood and check the dip stick. Color is a light brown and the fluid is just edging the "HOT" zone on the stick. Is it really time to change it again so soon? I thought after the first 60K change, it's every 30K after that. Any advice or insight is appreciated.
Old Jul 9, 2014 | 01:41 PM
Steve244's Avatar
5 is replace engine coolant.
Even if it were "3" I'd go 30K at least between ATF drain/fills. The MM works on operating conditions and doesn't know you changed it 8K ago.
My "3" code just came at 71K and I changed at 60k. I'll let it go until 90...
Old Jul 9, 2014 | 02:07 PM
ishcm's Avatar
Sorry it was B3. I was just looking at the manual and thinking I should change the coolant since it's been 5 years. So I guess I'll let it go till 90K then, unless I feel something weird in the gears. Thanks.
Old Jul 9, 2014 | 02:26 PM
bensenvill's Avatar
so when is it required for manual trans fluid changes?
Old Jul 9, 2014 | 03:23 PM
Steve244's Avatar
At mm 3 or whenever the mood strikes you.
I'm not sure when MM3 comes up, before this month I thought it was over 100K but 70K seems more likely. This is for A/Ts. Manual transmissions should need less frequent oil changes.
regular.dude
Oct 6, 2014 03:59 PM
tafkam
Mar 7, 2013 07:54 AM
JDMxGE8
13
Mar 20, 2012 02:04 AM
pdculbert
Jun 3, 2011 08:15 PM
Edison Carasio
Aug 20, 2009 06:08 PM
