Front ABS Sensor Rust/Corrosion
Old Feb 6, 2010 | 11:59 AM
FSchmertz's Avatar
So I'm have my front bearings replaced at 65,000 miles (seems early for a Honda, but I already posted in that thread), and the repair guy called and said the ABS sensors in the front had corroded themselves in the mechanism, it was a mix of cheap plastic and metal, and he needed to replace them 'cause they couldn't be removed without damaging them.
Thoughts?
Old Feb 6, 2010 | 02:53 PM
FITTECH's Avatar
Thoughts?
Most cars, all makes have this issue. It is just like that for some reason. I think it has to do with a chemical reaction of some sort. When the new snsr's get installed try lubing them with Sil glide (synthetic lube) this may help.
Old Feb 6, 2010 | 03:08 PM
Daemione's Avatar
The ABS sensors are plastic, that's obviously not gonna corrode. They slot into holes in the knuckle/spindle, which could conceivably rust/corrode enough to seize the sensor . . . but I can't see it as being very common. A few seconds with a wire brush and a rubber mallet popped my rear ones out no problem. Maybe the fronts are more prone to problems.
How much salt/weather do you drive in?
Old Feb 6, 2010 | 03:32 PM
FITTECH's Avatar
Lots of salt on the roads in Ontario. I am a Honda tech and see this happen all the time. All makes have this issue, because they dont want to pay the extra cost of the lube when manufacturing. Remember 1 cent per car adds up when you make thousands of them.
EggHead
Nov 11, 2016 08:21 PM
jdDC
Dec 30, 2015 02:52 PM
GregDavis11009
Oct 28, 2015 08:11 PM
hondafit_03
Jul 25, 2011 08:01 PM
glen62
Jul 1, 2010 10:28 PM
