CEL on, but can't read codes......
Old Mar 27, 2010 | 04:59 PM
65olds88's Avatar
My CEL came on few days ago in my '07 Fit Sport A/T with 37,000 miles on it. I went to hook up my Actron II code reader, but it will not let it link up to the car. It keeps saying link error, I want to know if these cars will not let you read the codes yourself and they force you to take it to the dealer or if there is just something wrong with my car. Other than disconnecting the negative battery cable is there any way to reset the CEL or better yet to read the code to see what it is?
Thanks
Old Mar 27, 2010 | 05:21 PM
PachmanP's Avatar
Try another code reader. The one I have wouldn't pull the codes, but my friend's and one I borrowed from advanced auto both worked. I think there's just something weird or nonstandard enough that it messes with some readers but not others.
Old Mar 27, 2010 | 05:24 PM
Kishore's Avatar
I believe Honda uses ISO Communication Protocol
The Connector
Pin 2 - J1850 Bus+
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 6 - CAN High (J-2284)
Pin 7 - ISO 9141-2 K Line
Pin 10 - J1850 Bus
Pin 14 - CAN Low (J-2284)
Pin 15 - ISO 9141-2 L Line
Pin 16 - Battery Power
J1850 VPW--The connector should have metallic contacts in pins 2, 4, 5, and 16, but not 10.
ISO 9141-2--The connector should have metallic contacts in pins 4, 5, 7, 15, and 16.
J1850 PWM--The connector should have metallic contacts in pins 2, 4, 5, 10, and 16.
Match the pins of Actron II to your OBD connectorr. Do they Match?
Did you follow the proper porcedure for connection the code reader, if not they will not hand shake and will come up with link error
Old Mar 27, 2010 | 05:31 PM
JamesBizzle's Avatar
Actron should work. I have one and it works fine.
Is the key in the II position with the car off? ... The codes can only be read while the car's off and the key's in this position.
Old Mar 28, 2010 | 10:28 AM
65olds88's Avatar
Key is in II position with engine off, its weird because I've never had this problem with my scanner before it works for all of my other cars with out a problem. Maybe I'll go to Advanced to see if they can scan it and see if theirs works on the car..........
Old Mar 28, 2010 | 08:31 PM
srad2drag's Avatar
I have the same problem with my Actron. My fit is the on ly car the gives me problems
Old Mar 28, 2010 | 08:35 PM
crash001's Avatar
Check ur gas cap
Old Mar 2, 2016 | 05:11 PM
dwtaylorpdx's Avatar
I use my Bosche one while driving or with just the engine power on.
Works fine. Kinda like having torque without some of the cool gauge functions.
FITDragon
Nov 11, 2021 09:08 PM
The Proper Fit
Nov 24, 2017 11:14 AM
Smackhead-johnny
Nov 11, 2016 04:15 AM
markielowski
Jan 2, 2011 03:08 PM
Steve
May 4, 2005 11:16 AM
