Service Manual Jazz 2006?
Old Apr 15, 2010 | 03:35 PM
qwerik's Avatar
Question Service Manual Jazz 2006?
Hi,
can somebody please tell me where to download the Service Manual for the Jazz/Fit 2006 ?
I need the manual to disassamble this Radio to install an iPod Adapter
Old Apr 18, 2010 | 04:09 PM
qwerik's Avatar
Can nobody help?
Old Apr 18, 2010 | 07:48 PM
seeremlive's Avatar
Check your private message
Old Apr 19, 2010 | 10:26 AM
cr4zy3lgato's Avatar
if i remember correctly, i think there is a diy in older threads...
Old Apr 19, 2010 | 10:59 AM
qwerik's Avatar
@seeremlive: thank you very much but this manual i found in the internet too. It's not that one i searched... With this manual you just see the Honda Fit 2002-2005 an not exactly that i own :-(
I search for the manual for the Fit 2006 to disassamble the original radio... i want to install an ipod adaptor and don't kno how to dissasamble the radio you see on the picture in my threat.
Old Apr 19, 2010 | 01:35 PM
secondspassed's Avatar
I imagine the radio should be the same as the one here: Wrap a screwdriver in some tape, try opening the glovebox and getting your hand way back there to push from behind and go at it. It just needs to be pried off/ pushed off. There probably isn't anything that needs to be removed first.
Old Apr 26, 2010 | 02:48 AM
qwerik's Avatar
I've found some manuals to disassamble the radio:
AUDIOLINK Honda Jazz 2005
Honda Jazz Club - Honda Jazz 2006
but it would be nice to have the "Service Manual" for the Jazz 2006. Can't somebody tell me where to download it? Any Rapidshare Links, Torrents or direct download locations?
Old Apr 26, 2010 | 03:21 PM
F0NIX's Avatar
I don't have the servicemanual but I have the instructions on how to remove that stock CD/Tuner unit as I have done in myself in my Jazz 2007. Below the unit under the temperature display, and abowe the cupholders, there is one plastic panel fastened with one x-screw. When that panel is removed you would get to those two bolts that holds the stereo unit. They are way back up against the unit, if you bend long enough down you could see them.
I tried to make a DIY here:
https://www.fitfreak.net/forums/fit-...-jazz-fit.html
And the instruction that came with the audio face panel can be dowloaded from here:
4shared.com - document sharing - download 2006 Jazz - Audio Face Panel Installation (low_res).pdf
Old Apr 26, 2010 | 05:28 PM
qwerik's Avatar
Thank you very much! A very good instruction to remove the radio
Old Apr 27, 2010 | 09:06 AM
mgutt's Avatar
Skibum
May 30, 2008 03:29 PM
= Paul =
May 10, 2008 07:20 PM
joe bloggs
Mar 30, 2008 07:34 PM
SupaLova
May 30, 2007 04:56 PM
b17gsr
Mar 29, 2007 11:19 PM
