cruise control still doesnt work ..... Why???---help
Old Apr 21, 2010 | 05:45 PM
FELIXY69's Avatar
ok so after a year of trying to fix it ... It still doesnt work
it would turn on but can't set the speed
The only time i can get it to work is after I reset the battery but it would only work alittle
If I restart the car it would stop working
Can someone give me a complete wiring diagram for the unit so I can take it apart ....?
thx
Old Apr 26, 2010 | 07:59 AM
E = Mc2's Avatar
I hate to go with the obvious, but when did the problem start? Was it when you put your LED tails in?
Old Apr 26, 2010 | 03:14 PM
seeremlive's Avatar
This is a big problem with LED tail lights on all makes of car. The cruise circuit thinks that the brakes are on and won't engage all it takes is a little floating voltage in the circuit. Not enough to light the lights, but enough that the cruise shuts down.
Adding diodes can help. They are one-way electrical "valves"
Another problem could be the clutch cut off switch if your are running a MT
Old Apr 26, 2010 | 10:13 PM
FitPilot's Avatar
My dad put LED's in his suburban and the cruise stopped working, I put the old bulbs in for him and problem was solved. The system doesn't like LED's and wont let the cruise work properly.
Old Apr 27, 2010 | 08:12 PM
FELIXY69's Avatar
well LED tail was the first mod back in 2007, it worked till i installed grounding wire in last 08, then another guy fixed it for a bit till i got emanage in a couple of months ...then it's been like that
nyjdmevo
Mar 16, 2010 10:21 AM
ken_vs_ryu
Apr 28, 2009 08:02 PM
trill
Apr 7, 2008 03:04 PM
Minisota Fit
Jan 27, 2007 08:03 PM
sLiVeRwOrM
Jan 12, 2007 07:06 PM
