Oil Life Meter is finally working
Old May 31, 2010 | 06:30 PM
Jensen Healy's Avatar
When I first bought my Fit back in February, for the 2 months I drove it and put a little over 200 miles on it, the Oil Life Meter remained @ 100%. I know I didn't do much driving then, but I still expected to at least see it drop to 99%. After that I got the oil changed in mid April with synthetic blend oil. I reset the Oil Life Meter too. And now 200 miles later I see my Oil Life Meter has finally changed to 90% That's kind of weird, I wonder why it didn't change before and at what mark would be a good idea to go in for my next oil change?
Old May 31, 2010 | 06:42 PM
Antpwny's Avatar
It doesn't change as proportionally as you think it would. It drops by 5%'s and 10%'s at a time.
Old May 31, 2010 | 07:23 PM
spreadhead's Avatar
Old May 31, 2010 | 10:27 PM
grtpumpkin's Avatar
The oil monitor partially bases its assumptions of oil life on RPM recorded by the ECU, if you do a lot of highway driving you will see your oil monitor change more rapidly than someone who just putzes along in town at lower RPM. That being said, 200 miles isn't nearly enough for the oil life to show a change. I would crap a turkey if my oil life changes in that few miles! Of course i put about 200 miles on my car every day but still....
Old Jun 1, 2010 | 01:17 AM
Koi's Avatar
Koi
MM goes down by 10% every time, until 15% at which point it goes down by 5% and then into the negatives if you don't reset.
Old Jun 1, 2010 | 01:41 AM
E = Mc2's Avatar
Mine is at 50%, with the most recent oil change some 4500 miles back... I average about 1000 miles for every 10% change.
Old Jun 1, 2010 | 02:19 PM
konespeed's Avatar
Thanks to my dad borrowing my car to take a trip up north my oil change is negative and i have to wait til saturday til i can change it.... is this terrible? i feel bad for my car as i drive it.
Old Jun 1, 2010 | 04:21 PM
Geez you're saying then that the reading can actually get below zero too telling you just how bad your oil is That's a good idea, even if that number can be painful to look at too. I wonder if the meter uses the time your oil has been in the engine in part of its equation too
Old Jun 1, 2010 | 06:47 PM
konespeed's Avatar
pretty much is that it counts the amount of miles you've driven when oil life is zero and it puts it as negative.
thanks dad for the -200 miles
Old Jun 1, 2010 | 08:16 PM
Koi's Avatar
Koi
Have you read your car's manual? MM doesn't take time into consideration, only miles & engine load/rpm.
Old Jun 2, 2010 | 12:26 AM
doctordoom's Avatar
Supervillain
if you read your owner's manual, all the info you need is there.
fufit905
Mar 23, 2011 05:33 AM
912
Nov 21, 2009 09:46 PM
db_et_ac
May 24, 2007 09:42 PM
OrangeBlossom
Aug 23, 2006 09:50 AM
billbob234
May 1, 2006 08:27 PM
