A warning about Air intakes!!
Old Aug 2, 2010 | 10:43 PM
score04w's Avatar
Originally Posted by patyong
Second that. Those manufacturers who manufacture CAI should include one of these in their package. Not sure whether it works though, anyone?
i think your cai needs to be two pieces in order to use a bypass thing.
Old Aug 4, 2010 | 04:57 PM
S4guy2000's Avatar
Originally Posted by cr4zy3lgato
Here's the one i did... the elbows come from U bent tubing, everything except the the filters came from vibrant performance. Heat isn't really an issue, the only thing is what's coming from the rad hose... i will probably shield the aluminium with Ayrfoil (kind of aluminium bubble wrap) sorry for the pic, it's from this spring and i made some improvements (yes including cutting the hose clamps...) i'm also working on replacing the breather by an oil catch can... so stay tuned... lol
I don't think that modding the stock airbox really is better than what i did, but to each is to own... btw if you're going to go this route, you should know that you'll have to remove the resonators inside the air box, having a stock look might be an advantage though...
I bet if you hit that with a laser thermometer after you drove for awhile you would see some seriously high temps, and with that filter being 360 degrees its pulling air from all around it, including the air coming and swirling by those exhaust manifold tubes. There does appear to be some space which is good, but I would still bet you aren't getting the full benefit of cold air, especially if you sit still, you don't have moving air, and I bet that tube gets heat soaked really easily as well as everything else around the filter. Only a dyno would say for sure, but even then I don't forsee this approach to be very beneficial over modifying the stock airbox or boxing in your setup now with something that won't absorb heat, or getting a true air pick up point which is outside of the engine bay and away from its hot air.
Old Sep 2, 2010 | 11:17 PM
fr_wilson's Avatar
I found a low mileage engine (less than 10k). I've got the Helms manual which says the engine comes out under the car. Not an easy task for the home garage. Does anyone know If the engine will come out the top? I'll post some pics of the trashed engine when I get it out.
Old Sep 2, 2010 | 11:36 PM
sevenaprils's Avatar
Josh, or gd3kamiwanaB username, pulled his motor after he did some pretty good damage running boost. He swapped another L15A in, and if I remember the pictures showed the process with an engine hoist and removing the old/installing the new from the top side.
yep, here's the link
Old Sep 3, 2010 | 08:57 AM
seeremlive's Avatar
Front Wheel drive engines are always easier to drop out attached to the whole front subassebly, with the wheels and all. This is how they are put in. In a home garage thsi is abit of a challange due to lifting capabilities and height restrictions. I looked at mine just now and it looks like with some careful planning you should be able to remove the half shafts, at the transmition and then suspend the engine, remove the motor mounts and then raise the passanger side first and slip it out.
Old Sep 3, 2010 | 10:49 AM
2Legit2Fit's Avatar
Just so everyone knows, K&N makes a product known as "Outerwears" for their ATV intake applications. It is essentially a cover that slips over the cone of the intake and is designed to allow the same amount of air in without allowing dirt, water, mud etc. to enter the manifold.
When I had a K&N CAI on my Chevy Colorado ZQ8 I used one of these and it worked great. Hope this helps anyone with concerns...
Old Sep 4, 2010 | 12:56 AM
fr_wilson's Avatar
Thanks for the link to the engine installation pictures. Looks like he put in in from the top. That's what I'm going to do. Any suggestions on things to do to the motor before it goes in?
Old Sep 18, 2010 | 01:27 AM
mdsniper7's Avatar
cai i wish water log in florida damn hurricans
Old Sep 19, 2010 | 06:59 PM
Remedi's Avatar
I've had similar experiences when I owned a Civic back in the day. Right now, I just stuck to k&n filters in all my cars and so far so good.
Ba_forareason
Jun 25, 2018 01:31 PM
GinoLicious
Aug 7, 2013 09:57 PM
lowkeymods
Aug 31, 2012 07:42 PM
alabastersilverjazz
15
May 23, 2008 09:49 PM
xcurt15
33
Nov 1, 2007 04:33 PM
