How often do you guys change your oil?
Old Aug 11, 2010 | 11:07 AM
pb and h's Avatar
If you look close at my oil analysis(posted above) you will notice that I had 65k on the car and 10k on the oil. The analyst suggest running the oil to 11k or 12k. 0w20 is a great oil and can easily make it to 10k. The maintenance reminder is a recommendation. This can depend on the type of oil but I am betting the recommendation is based on a non-synthetic oil which is a more conservative route.
When I change my oil it is always black but the insides of the engine still look good after 101k.
Old Aug 11, 2010 | 12:16 PM
S4guy2000's Avatar
Just follow the maintenance minder. Honda designed it and it takes a lot of things into consideration. Honda also designed the engine to run on conventional, and that is fine and good. I went with a quality synthetic (Pennzoil Ultra) so even if the maintenance minder streches the oil out for a bunch of miles the oil will still be good and I won't have to worry about it. Hondas (especially Fits) are easy on oil and could probably go 7500+ miles or more on conventional oil but I chose synthetic just for my peace of mind.
Old Aug 11, 2010 | 01:20 PM
mahout's Avatar
The real key is the CHANGE in viscosity and contaminants. You need to post an analysis of virgin oil. Your contents of iron (Fe) and Aluminum (Al) are not too different from ours;perhaps a little higher but not statistically so. Your Ca, Mg, and Zn are higher than ours.
However I didn't see pH which is a good measure of acidity and shear strength.
Old Aug 11, 2010 | 01:53 PM
pb and h's Avatar
I was thinking of sending this oil off for analysis at the next change interval and I will send in a sample of the fresh stuff and check the pH as well. I am in for the know. Then we can all learn something.
Old Aug 13, 2010 | 03:54 AM
Super Mario's Avatar
I go by the maintenance minder and I'm averaging about 7500 miles before it hits 0%. Running Pennzoil Platinum 5w20. Before I switched to Synthetic the maintenance minder was telling me to change around 5K. Not sure why my intervals are longer now just b/c of synthetic.
Old Aug 13, 2010 | 10:24 AM
SoUnFit's Avatar
I'll most likely do 5k intervals. The manual says change the filter every other time but idk about all that. Oil and filter every 5k should be good.
Old Aug 13, 2010 | 12:10 PM
HOLY FIT!!'s Avatar
i change every 3k with a premium synthetic and a new filter. Right now im running penzoil ultra.
Old Aug 16, 2010 | 05:21 PM
EDJ82's Avatar
I change at 5k intervals with Mobil 1.
Old Aug 20, 2010 | 01:24 AM
dexterousdeven's Avatar
Thanks for the replies. I'm planning to use synthetic oil the next time I need an oil change, which should be in the next few months. It seems like Mobil 1 is a good brand to use, any others I should consider?
Old Aug 20, 2010 | 06:50 AM
Selden's Avatar
Whatever synthetic is on sale. They all far exceed OEM requirements.
mxl180
Aug 26, 2012 05:21 PM
FlipsFit
Aug 19, 2011 11:32 AM
MaxSoul
Nov 20, 2010 05:25 PM
Lynn
Jun 15, 2009 05:03 PM
rocksnap
Jun 4, 2008 01:26 PM
