How often do you guys change your oil?
Old Aug 7, 2010 | 03:41 PM
dexterousdeven's Avatar
I have an 08 Fit Sport, and right now it has about 8300 miles on it. I got my first oil change around 5200 miles, and I was wondering how often you should change your oil? I've heard anywhere from every 5 thousand miles to every 3 thousand miles. Also, if I wanted to go with synthetic oil would I have to wait until I have more miles on my car? Thanks.
Old Aug 7, 2010 | 04:38 PM
wjordan52's Avatar
Not sure if the '08 has this feature, but on my '10 I go strictly by the Maintenance Minder. My first oil change came at 10,114 miles.
Old Aug 7, 2010 | 07:05 PM
Black3sr's Avatar
Isn't this the week to change oil? I had mine done on Thur it was at 16,000kms or .62 x 16,000 = miles. Next when indicator says 15% or one year as dealer suggested so likely next Aug.
Old Aug 8, 2010 | 02:22 AM
Koi's Avatar
Koi
I just do mine every 5,000 miles like I used to on my old car. Don't think it's necessary with Mobil1 synthetic but it keeps me on the ball with maintenance in general.
Old Aug 8, 2010 | 02:54 AM
Type 100's Avatar
No maintenance minder on our GDs or GEs, so people here go by the 5000km/10000km interval depending on oil used. The shorter interval is used for mineral oil.
5000 km = 3100 mi.
Since I've been taking the car to trackdays, I shorten my interval for full synthetic oil to account for the additional abuse: 7500 km between changes (= 4650 mi).
Old Aug 8, 2010 | 08:31 PM
pb and h's Avatar
maintenance minder on mine is usually about 10,000 miles which is when I change my oil. I use Mobile 1 synthetic 0w20 and I have 102000 miles on my 2007 fit sport 5spd. My motor still looks new and I know this because I just did the first valve adjustment at 101000 miles.
Old Aug 8, 2010 | 09:14 PM
polaski's Avatar
Every 3500 miles (roughly 3 months, MM down to 30-40%), but motorcraft 5w20 is $12 for 5 qt so no biggie.
3 mile commute to work = teh suck for oil, and we get some harsh winter here. Better safe than sorry.
The civic got it every 2500 but it had the excuse of blowby and turning it diesel black.
Old Aug 8, 2010 | 09:21 PM
Blue-Civic-Hybrid's Avatar
I change my oil once every 10,000 miles and I use either Royal Purple or Mobil 1 Extended oil.
No need to really change it before that unless you have the money to burn.
Old Aug 9, 2010 | 08:13 PM
coldstorage5's Avatar
Mobil 1
Every 5000 miles
Old Aug 9, 2010 | 08:36 PM
Selden's Avatar
Out of curiosity, how far out of spec were the valves?
Old Aug 9, 2010 | 10:06 PM
mahout's Avatar
We base recommended oil changes on our analyses of viscosity degradation. That's 3500 miles for conventional hydrocarbon oil and 6000 miles for synthetics and always with a new oil filter.
Old Aug 9, 2010 | 11:32 PM
Black01's Avatar
Pretty much the same but I always go by the percentage. I usually change my oil with inconsistent percentage. Sometimes 15% or 30% and sometimes 20% but most commonly at 20%. My engine also looks good since I saw it when I did my valve adjustment. I'm using a new mobil oil filter and mobil clean 5000 semi synthetic oil(This oil is cheap and from my experience its good).
Old Aug 10, 2010 | 02:19 AM
Texas Coyote's Avatar
I have changed mine 6 times in 32000 miles and have used Mobile 1 or Royal Purple 5-20 until the last change before upping the boost to 10 PSI when I changed to Mobile1 10-30
Old Aug 10, 2010 | 03:43 AM
patyong's Avatar
I changed mine every 9,000km - 10,000km. Using Mobil 1 0W-40 and honda filter for each change.
Old Aug 10, 2010 | 08:59 AM
pb and h's Avatar
here were the clearances:
#1 - I - .009 E - .010
#3 - I - .009 E - .007
#4 - I - .009 E - .011
#2 - I - .009 E - .008
I adjusted them to I - .006 E - .012
I did this because the Intake seemed to loosen up while the Exhaust seemed to tighten up.
also, I have had an oil analysis a while back:
Oilreport.jpg?t=1281444887
Old Aug 10, 2010 | 12:04 PM
GreekHondaJazz's Avatar
Mobil 1 0w20 Advanced Fuel Economy
if you want your car to run the best then use Mobil 1 0w20 Advanced Fuel Economy. I have been using it for the past 2.5 years in my jazz and fit. Its the best oil ever. I drive 5000 miles before I change my oil. And I run my cars hard.
Old Aug 10, 2010 | 12:09 PM
Roo's Avatar
Roo
I change mine every 5,000 miles
Old Aug 10, 2010 | 01:05 PM
chewy's Avatar
i change mine every 5000 miles I use mobile 1 5w20... I'm going to switch to royal purple since I'm going to get the hook up =)
Old Aug 10, 2010 | 02:25 PM
Roo's Avatar
Roo
my bf told me that stuff was the best!
Old Aug 10, 2010 | 02:37 PM
JDMxGE8's Avatar
I change my oil/filter every 3,000 miles.
