Hot and long South Florida Summers and engine oil
Old Aug 23, 2010 | 01:01 PM
ftlmatt's Avatar
i live in south florida, Fort Lauderdale, and the summer here is not only long, with unbearable heat and humidity from about May until late September.
i was reading that using a higher viscosity oil is recommended in climates like this.
Honda still changes my oil since it is still under warranty. correct me if i am wrong, but the Fit takes 10w-30 oil.
that should be fine for this heat, but just wanted to make sure. and when my warranty is up, not sure if i should continue to use Honda's recommended factory oil, or use a synthetic oil.
Old Aug 23, 2010 | 01:04 PM
5speedwonder's Avatar
i use 5w-20 fully synthetic mobil 1...live in tampa and i've never had any problems.
Old Aug 23, 2010 | 02:31 PM
08fithappy's Avatar
I also thought the fit used 10w-30 but looked in the manual. The honda recomendation is 5w-20. Just use this and u will be fine
gOzP19
Oct 18, 2014 01:04 AM
ikutoisahobo
29
Jun 22, 2014 11:57 AM
hondafit_03
Aug 13, 2011 11:05 PM
Eugene.Atget
Dec 11, 2010 07:21 PM
dave brown
Aug 26, 2008 05:09 PM
