brake fluid for tracking
Old Sep 29, 2010 | 08:21 AM
jonno86's Avatar
Hi,
I've a jazz gd3 ausdm.
Do you guys recommend using DOT5+ fluids? Since in the service manual says DOT 5 is not compatible with my braking system.
What is your thoughts on that?
Regards,
Old Sep 29, 2010 | 08:41 AM
Type 100's Avatar
Avoid DOT5 at all costs. The composition of DOT5 is way different compared to DOT3 and DOT4.
However, DOT5 and DOT5.1 are two different beasts.
The compatible brake fluids for our cars are DOT3 and DOT4...you could probably use DOT5.1 but don't quote me on that. DOT4 is sufficient for track use, although drive/brake hard enough and you could still induce fluid boil on it.
Old Oct 6, 2010 | 10:17 PM
THEproFIT's Avatar
motul rbf600
if u boil that, u r truly a superstar
if u r a superstar, try rbf660!
Old Oct 6, 2010 | 11:31 PM
Type 100's Avatar
Originally Posted by THEproFIT
motul rbf600
RBF660 is still rated as DOT4.
Old Oct 6, 2010 | 11:42 PM
apexanimal's Avatar
dot 5.1 would be fine, but FAR overkill... and you'd have to bleed the system several times over to eliminate as much of the previous fluid as humanly possible... you'd go through quite a lot of fluid, and money, in changing the system over to it...
a good dot 4, like ate's new sl6 or super blue/typ200, is all you would most likely ever need...
dot 4 is a solid upgrade and worthwhile imho, but 5.1 is a bit silly...
.02
Old Oct 7, 2010 | 02:51 AM
jazz6768's Avatar
used Eneos...
Old Oct 7, 2010 | 06:02 AM
Type 100's Avatar
I've used ATE Super Blue myself, it's pretty good. It boiled after my instructor drove three really hard consecutive laps of Batangas Racing Circuit, though - three seconds faster than my best lap time. That would be an extreme scenario though.
I've since changed to Motul's regular DOT4...just as good.
Old Oct 7, 2010 | 08:04 AM
555sexydrive's Avatar
I'm using SpeedMaster Super Dot4.
QuanticBeat
May 27, 2024 10:19 AM
Gekisen
27
Jun 23, 2019 11:53 AM
AppleMac*Fit
Nov 14, 2010 01:40 PM
kennef
Car Shows, Events, and Racing
Nov 13, 2007 12:27 AM
chibitul
Jul 24, 2005 05:32 AM
