How to reset the ecu after battery change
Old Nov 24, 2010 | 12:57 PM
mcrobie's Avatar
I changed the battery and the ECU computer shows the check engine light and the engine misses under acceleration. How do I reset the ECU myself without a computer? Will it reset by itself and how long will it take?
Jim
Old Nov 24, 2010 | 01:24 PM
DiamondStarMonsters's Avatar
Jim
Resetting the ECU usually just requires pulling the battery and touching the terminals together for like 10-15sec.
The terminals from the car, not the battery terminals themselves, in case that needed clarification
It sounds like you are having a voltage drop causing your spark to blow out or just not ignite the mixture fully.. make sure the terminals are making good contact on the battery its self.
Autozone can pull the codes for you to determine what the problem is if tinkering with the contact surfaces doesn't resolve the matter.
Old Nov 25, 2010 | 11:43 AM
willy65000's Avatar
I've disconnected my battery lots of times and never had to reset my ecu. Is it the stock battery? I noticed that when I tried an aftermarket battery that the posts on the new battery were not raised off of the top of the battery like they are on the stock one which meant the terminals didn't clamp tight enough. I don't know.
Good Luck
Old Nov 25, 2010 | 11:48 AM
SilverBullet's Avatar
When you disconnect the battery you reset the fuel trims to default. The car wont pass emission until all 5 emissions codes are rebuilt. Your car will still run but starting from default settings and with the degrading sensors it might not be as efficient.
Old Nov 25, 2010 | 11:50 AM
Jim
It wont reset the DTC code but reset the fuel trims if you disconnect the battery. You need a scan tool to read codes and reset them from the port under the steering wheel.
naylynnaung
Feb 20, 2016 06:39 AM
jenos
May 20, 2011 10:48 AM
Tressie
Nov 29, 2009 02:10 PM
Yongjin
Mar 30, 2008 09:24 PM
