Best rim sizes...
Old Jan 27, 2011 | 07:25 AM
Bthasht's Avatar
^^ so what rubs inner liner or fender on the +40 offset? Rub sidewall or tread? Front or back?
Old Jan 27, 2011 | 03:22 PM
datkidpatrick's Avatar
i have 15x7 +35 and it slightly rubs on the front and on the back on hard dips on tein springs...it probaby would be less if i ran 195/55/15 tires, im currently running 205/50/15... haven't rolled the back lip or tucked the fender lining yet, but i doubt it'll rub at all after...
Old Jan 27, 2011 | 06:43 PM
mahout's Avatar
Don't bet on the 195/55x15 being better. the 205/50x15 is 23.07" and the 195/55 is 23.44" diameter. Before going farther mark the tires with shoe polish to find out where the tire is rubbing. If its on top of the tire you won't improve. if its on the side you have a chance.
Old Jan 27, 2011 | 06:48 PM
it rubs up front slightly on the clip that holds the fender lining... the back it hits the fender lip on the tread of the tire... i think the -5mm width on the 195/55's should make it clear.... but i will most likely have my fenders rolled before then, prob get 16's and go wider...
Old Mar 29, 2011 | 01:57 PM
vipernick913's Avatar
I'd say 16inch from my experience.
Old Mar 29, 2011 | 09:47 PM
mahout's Avatar
Originally Posted by smellslikeFIT
I'm looking at getting some rims for the ole fit but I've heard that you have to watch out cause some size of rims will rub if some people are in the back seat, what's a bigger/safe size to roll with?
I wouldn't lower it anymore than 1.5 in, if that helps to figure this out.
Pretty safe specs are minimum offset 45 mm if lowered (or not) and 42mm if stock ride height. Generally speaking 195 and 205 section tires are preferred keepnig the diameter at 24" or less. Less to 23" if lowered.
The bigger the wheel diameter the narrower the section.
Old Apr 3, 2011 | 12:21 PM
THEproFIT's Avatar
Originally Posted by redrumm
it depends on width and offset.
15x7 with a 35 offset is about as low as i would go if you dont want to rub
195 - 50 tires are a good fit too.
u a gambling man?
i bet the above rim size will rub when lowered
remember stock offset is 55mm!!!
Old Apr 3, 2011 | 04:26 PM
fitster's Avatar
i ran 15x7 35 offset with 8mm spacers on spoon springs no rubs no problems
205/50/15 tires too
Old Apr 6, 2011 | 12:07 AM
The Assassin's Avatar
205/50/15 tires too
Are you lowered?
Old Apr 6, 2011 | 02:31 AM
islander6677's Avatar
@ryanroland
Rims and drop look good!! just curious where did you pick up the rims? I just picked up an 08 fit sport and of course would love to change the shoes on this badboy!! any ideas are greatly appreciated.
Old Apr 6, 2011 | 07:34 AM
Bthasht's Avatar
People please check dates. This thread was bumped up by a new guy trying to get his 20 posts. The op has rings by now im sure.
Ryan is on eibach sportlines with sparcos. Tire rack sells sparco, but try for a civic. Tire rack wont sell you a set in +38 offset for a fit.
Azizul Zulzaha
Mar 22, 2011 01:01 AM
Halcyon
Nov 25, 2010 07:15 PM
Frenchi169
Mar 31, 2008 10:49 PM
randomracer
Mar 4, 2008 07:26 PM
MiniMeRR
Mar 4, 2008 10:22 AM
