Shift Release Locked while Parked
Old Mar 19, 2011 | 11:36 PM
PattyM's Avatar
I was parked at the beach this evening. Went to start my 2007 Automatic Fit, and it wouldn't start. Called the Automobile Association. While waiting, I read the manual that tells you to pry off the little cover and stick your key in to release it out of Park. I did that, went to neutral, and easily started the car. Cancelled the AutoClub and drove home. When I parked, it locked up again. I did a search here and didn't see this problem mentioned. Anyone heard of this happening? What might it be?
Old Aug 24, 2011 | 10:23 AM
hgbarria's Avatar
Shift Lock
Hi Patty, did you manage to fix this problem? My Fit did the same yesterday...
Old Sep 12, 2011 | 01:03 PM
hgbarria's Avatar
Shift Lock - Fixed
Hi, did you notice if something else stop working also? In my case was a fuse, a 15 amp fuse that broke. It affect the horn, the shift lock and the central door lock. It is identified in the fuse box as a horn fuse only.
hqly2001
Apr 23, 2018 08:21 PM
Rfitfit
Dec 14, 2015 10:20 PM
over40pirate
Jun 7, 2014 08:35 PM
prhkgh
Jan 22, 2013 10:31 AM
kaboodels
Jan 27, 2006 06:26 AM
