extended studs
Old Mar 29, 2011 | 12:33 PM
score04w's Avatar
extended studs
Does anyone know how to replace the factory studs in the rear with some extended studs. Was looking at it earlier and had no idea. Any help would be great.
Old Mar 29, 2011 | 04:54 PM
nxtfit_08's Avatar
those are easier then the fronts you have to take the hub out and bang them threw
Old Mar 30, 2011 | 10:16 AM
JCrimson's Avatar
D notch them! screw taking the hug apart
Old Mar 30, 2011 | 12:31 PM
score04w's Avatar
wouldn't even know how to go about taking the hub apart.
Old Mar 30, 2011 | 01:46 PM
nxtfit_08's Avatar
her you go
step 1 take the drum off
step 2 bang out the old studs
step 3 take off the dust cover on the hub
atep 4 take the bolt off witch is i think a 32mm
step 5 slide hub off
then put it back together the way you took it off in reverse make sure you dont over tighten the hub bolt cause then it may get too tight and mess up the hub bearing it self
Old Mar 30, 2011 | 04:19 PM
score04w's Avatar
just finished. thanks for the help!
Old Mar 30, 2011 | 04:24 PM
nxtfit_08's Avatar
yes sir>>>>>>>>>>
Vash
Sep 15, 2016 09:40 AM
Rollerboots666
Apr 10, 2014 12:02 AM
thefit09
Mar 3, 2013 10:39 AM
andyd
Jun 14, 2010 05:57 PM
RMike
Greater Calgary Community
Jul 20, 2009 10:17 PM
