Alternate tire size for 07 Fit Sport
Old Apr 12, 2011 | 08:25 AM
jessiejosco's Avatar
I need new summer tires for my fit sport. It looks like Honda picked a wacky stock tire size and you can only get high performance tires.
I want to put on some low rolling resistance Michelins, but the closest size is 195 60 15. The speedo would only be slow about 3% and the highway rpms should drop a bit. Both good side effects as far as I am concerned.
Has anyone run this size on the Fit? Or any other size that you can get in a normal tire?
Old Apr 12, 2011 | 04:40 PM
Jodele's Avatar
I'm running 205/50ZR16 on my '07 Sport.
Old Apr 16, 2011 | 07:24 PM
sdnhatb's Avatar
I need an answer for this too. im looking to run shat will help the most with something that helps the most with mpg
Old Apr 16, 2011 | 07:30 PM
harispirzada's Avatar
I was running 215 50 15 on my sport rims before I sold them. With that size, you're speedometer is barely off
Tire Size Calculator - Discount Tire Direct
Old Apr 17, 2011 | 07:40 AM
Where I live 50 series is not a good idea. I would end up with a bent rim.
Old Apr 18, 2011 | 03:34 AM
j5ive's Avatar
the tire calculator works well. Also keep in mind that our speedo (odo) actually reads fast. So taller tires might actually fix that.
Old Apr 19, 2011 | 06:43 PM
mahout's Avatar
Those tires fit fine (undropped) but you can expect a drop in mpg more than you would expect from the equivalent gear change. People here have had better luck and prices with 185/60x15's. Only 1% change and apparently no effect on mpg.
Old Apr 23, 2011 | 10:05 PM
grilledcheese33's Avatar
205/50/15 on sport wheels here. No problems at all.
Old Apr 23, 2011 | 10:29 PM
Texas Coyote's Avatar
The Continental Conti Pro Contact is a low rolling resistance tire and available in the stock 195-55-15 size... I have some on my 2007 sport model but they are of older production and not said to be low rolling resistance.. They are much quieter, lighter in weight, and comfortable than the OEM Dunlops and can be rotated side to side which I'm not sure the later model can be but believe they can also. The ones I have are great on rural roads paved or otherwise.
Old Apr 24, 2011 | 09:14 AM
Just looking at Tire Rack. The Conti's are low rolling resistance but they get pretty bad reviews.
I would have thought 195 90 15 would give better fuel economy than the stock tire. The rpms should drop a bit and they are a bit narrower.
I have a set of Michelin MXV 4s in this size for another car, so I might throw them on the fit and see how they do.
Old Apr 24, 2011 | 12:08 PM
feddup's Avatar
options
Although not technically listed as LRR tires these are reputed to help mileage some. they get pretty good reviews as well. Although still running the stock dunlops I've had excellent experience in the past with Yokohamas and plan on purchasing these next unless something better arises.
Yokohama AVID ENVigor (H&V)
jeeves
Nov 28, 2017 07:03 PM
hoss10
Mar 31, 2011 09:28 AM
Drewnickd
Feb 4, 2011 04:09 PM
BayAreaKid
Oct 5, 2009 05:55 PM
Sugarphreak
May 24, 2008 09:10 AM
