Front disc replacement for JDM Fit
Old May 6, 2011 | 06:25 AM
wrx450's Avatar
Hi
I have owned a Honda Fit since 2004. It is a 2002 JDM model that was imported to Cyprus. Has now done over 185,000 klms and the front discs need replacing. The setup is front discs, rear drums. Honda is quite hopeless in Cyprus and have none in stock and want usual exorbitant amount to get me set.
Were the front discs the same between the Jazz and Fit?. i.e. can I get a set of 2002 Jazz discs from the UK.
I think the Jazz discs were 239mm, H 43mm and width 21mm. Are these the same. I am guessing yes.
Thanks
Old May 18, 2011 | 12:18 PM
B-boystance's Avatar
Not all brakes on the honda jazz/fit are the same it depends on the yead I found this out as I've had a few jazz's now (5 in all) some as donor cars. If you check what measurements that you have on your car I could send you a set of OEM secondhand brakes from teh UK as that's where I'm from and have swapped my calipers and uprated to a larger set of discs.
£40 for discs and pads plus postage.
will up photo's if you are interested.
Old May 19, 2011 | 09:59 AM
wrx450's Avatar
Hi
Yes I have been caught out. I have ordered a set of Jazz discs for the GD1 from EBC in the UK and they are slightly bigger, wider and have different height to the JDM Fit. The JDM are only 230mm v 239, 19mm vs 21 and different height as well. So they are useless to me.
Would be interested if you have the JDM size as the stealers here are a joke for new discs. €210 per set!!! EBC £60.
Mickey Hope
Jan 3, 2018 12:01 AM
terryb
European Fit Forums & Clubs
Dec 6, 2007 05:10 PM
Gordio
Dec 8, 2006 09:47 AM
HondaF1
Feb 24, 2006 04:06 AM
