215/40/17's and still rubbing!!!
Old Jun 16, 2011 | 07:35 AM
mahout's Avatar
Originally Posted by pacrimguru
i had to go with 195/40-17, cut and roll my fenders, and camber the rear to get them to stop rubbing.
Nice looking Fit but if you had gone with 195/40x17 on 45 mm OFFSET wheels you wouldn't have to do all that fender work.
Old Jun 16, 2011 | 08:36 AM
Bthasht's Avatar
^^ are those konig super mesh? Whats the offset on those? Im looking at getting the same set, but in polished
Old Jun 16, 2011 | 11:20 AM
pacrimguru's Avatar
thanks, i wish i did! my buddy owns jline rims and he ordered those for me promising a super aggressive fitment. i think he went too far.
those are jline SDMRL2's:
J Line Wheels
Old Jun 16, 2011 | 12:29 PM
MNfit's Avatar
45 mmm Offset is such a boring offset.
Old Jun 16, 2011 | 01:20 PM
mahout's Avatar
Boring? Compared to what? And what difference does offset make?
Old Jun 16, 2011 | 01:22 PM
mahout's Avatar
J Line Wheels
The offset is ordinarily cast into the back of one of the spokes or inner rim.
Old Jun 16, 2011 | 02:25 PM
MNfit's Avatar
compared to lower offsets . im running 42mm offsets on 16x7 with 205/45/16 and I have VERY LITTLE rubbing.
Its personal preference but I think it looks better when the wheel is pushed out closer to the fender. Im not talking about hellaflush offsets. I think it just looks better when the wheel fills out the wheel well.
Old Jun 16, 2011 | 10:22 PM
kodok3ribu's Avatar
compared to lower offsets . im running 42mm offsets on 16x7 with 205/24/16 and I have VERY LITTLE rubbing.
well i did that, with 15x7" wheels, 195/50/15 tires, offset is 38, cambered at 1* front and back, lowered with hks coilover.. and you know what? they RUB!! well, not all the time, just when running over big bumps at high speed.. so, yeah it looks better, but it creeps me out when i run over a bump and the wheels are rubbing... i'm afraid they will blow up and i'll be toast...
Old Jun 17, 2011 | 04:33 AM
MNfit's Avatar
Oh noes they rubbed! Big deal? I had 15x7 195/50/15 +32 front and +27 rear. The fronts rubbed under hard cornering and big bumps, the rears rubbed over medium bumps. So it rubs a little bit it's not the end of the world. If you are that conserened about rubbing then maybe you just need to stick to the stock rims and not lower the car.
Old Jun 17, 2011 | 09:35 AM
kodok3ribu's Avatar
Here's a quick question: if the tires rub during high speed, is there a risk of blowing up your tires? If not, then I'll live with it
Old Jun 17, 2011 | 09:56 AM
MNfit's Avatar
Hell if I know. If they are constantly rubbing under any kind of drivin then yes there is probable a possible the tire will fail. With my 15's the rears rubbed with bumps. It chewed the side wall up a bit but the wheel is fine. If it's like you say that it only rubs over bumps then I don't really see a problem, bit what do I know
Old Jun 19, 2011 | 02:22 AM
  #32
taFITta_sport's Avatar
Kam what's your drop on your car? Ive been on 17,s for the longest n I hardly ever rub. I'm running on eibach pros 1.6f 1.5r
Old May 15, 2013 | 11:36 PM
  #33
soasin's Avatar
Need help guys! Im running 15x8 +15 and i already rolled and pulled my fenders but i have some issues on the rear. Im still rubbing on the rear because of my rear bumper. What should i do on the rear bumper because it cant be rolled. And i want to go lower. Hmmmm please anyone? Thanks!
Old May 16, 2013 | 03:24 PM
  #34
TPColgett's Avatar
I have 225/45R 15's on 15x8 +25 at near stock ride height in the rear with HEAVILY rolled rear fenders . It still rubs.
Only solution for me it so add camber, so I had a custom set of shims machined to go onto the stub axle:
With these I should have around -3.0 degree's of camber and should be able to clear.
Since your at an even lower offset, and I am guessing much lower than stock you may have to make some significant modifications... What size tire are you trying to fit? Can you go "smaller?" Start by adding camber, and if that does not work try trimming the plastic bumper and then cutting and relocating the bumper tab is where I would go next.
Hope that helps!
Old May 16, 2013 | 08:26 PM
  #35
Previc93's Avatar
Im Running 225 With 8" Wheel And No RubbingOn Ksport Coilovers. Y Does Everyone Keep Saying U Can Only Run 205... I Laugh At That.
Roll Fenders Run negative Camber In Front Around -2 And Do The Rear Bumper Fix. Make Sure Toe Is Set At 0 Otherwise U Will Wear Tires.
Old May 16, 2013 | 11:24 PM
  #36
soasin's Avatar
My tire is 185 45 r15. How much did it cost you with that custom shims TPcolget?
Previc, i already zip tied my bumper but im still rubbing when i have a passenger at the back. Hmmm. I have EZ shims, but i heard they are hard to install and cost a lot when installing. I dont know for sure
Old May 17, 2013 | 12:32 AM
  #37
solbrothers's Avatar
Originally Posted by Demon Fit
You definitely need 205's, no matter what the offset is. The offset by itself may make you rub depending on how far the wheel sticks out... but 205/40's are a must!
wrong. tire size, wheel size, and wheel offset all play a role
SHOELAC3D
Aug 27, 2014 02:57 PM
sabawballs
Aug 17, 2012 04:11 AM
Happy__Fit
Jun 16, 2010 01:19 AM
jazz_do_it
Jun 3, 2010 11:56 AM
ds62987
Dec 15, 2008 09:36 PM
