New to the forums... Habing problems with my tachometer
Old Jul 7, 2011 | 01:20 PM
iraiduh's Avatar
hey there guys!
im new to this forum and im having trouble finding forums that help with tachometer issues....
So pretty much my tachometer has stopped working, it only stays at 1000 at all times, and i think it might be a loose wire, but i have no idea what wire is to what.
So if anyone can help me out i would really appreciate it, from providing a wire diagram to correcting me (is it really a wiring problem) p.s i drive an 08 fit sport
Old Jul 7, 2011 | 01:36 PM
Krimson_Cardnal's Avatar
Issue with the gauge control module [that's the gauge cluster unit]. Needs to be diagnosed, involves checking DTC-codes. Does tach stay at 1K even w/ ignition off?
Old Jul 7, 2011 | 01:39 PM
Bthasht's Avatar
Dont know, but has your cluster ever been taking apart for any reason? In my signature (below front end pic) you will see a link to tpms light. In there you will find how to pull gauge cluster out. There are three wire harness plugged to it. Check those for looseness or broken. Also while out see if your needle will move freely up.
Old Jul 7, 2011 | 11:00 PM
iraiduh's Avatar
@ Krimson_Cardnal nope, with the ignition off its below 1k but once i start driving it, it goes into 1k ans just stays there.
@ Bthasht i personally have never taken the cluster apart, but i think the previous owner did, because you can see marks were he shoved a screwdriver around the top shroud. But dude, i think your step by step link will be a major help
Old Jul 7, 2011 | 11:14 PM
You'll get it out alright, but figuring how to 'fix' it will be a problem if you don't understand what's wrong. Keep us posted, curious to see how this goes for you.
Old Jul 9, 2011 | 06:22 PM
iraiduh's Avatar
Well after pulling apart the cluster I found put that it wasnt a wiring problem :/ now im stuck cuz I have no idea what it could be cuz everything wass good under the cluster and the needle is fine as well. :/
F..it
Sep 3, 2020 07:52 PM
Hannyah
Mar 17, 2014 07:47 PM
Jhove
Dec 19, 2009 12:05 PM
Mapone
Sep 8, 2009 06:19 AM
Chikubi
Aug 24, 2006 11:07 PM
