serpetine belt-slipping
Old Jul 19, 2011 | 11:59 AM
blue line's Avatar
Recently noticed squeal, (about 100K) decided to change belt as adjustment screw seem to have bottomed out. So I got the belt, and a new idler pulley, as that seem to getting a bit noisy also. Followed DIY here to remove. Now comes the part--either hands are to big, or I'm just not coordinated enough to get the pulley and its assortment of funky washers back. The hole on engine block is to cramped to get bolt started!
any tricks of the trade much appreciated. thanks
Old Jul 21, 2011 | 01:12 PM
mahout's Avatar
Not sure of your problem but we have used a magnetic thin-walled bolt socket to engage bolts in difficult to reach places. Sometimes merely applying a good magnet to a steel closed end wrench will assist the bolt staying in place.We've tried taping the back of the closed-end wrench, too and that can work.
We do have a sideways actuated wrench here that really clasps the bolt too but you're not likely to have one of those.
good luck.
Old Jul 21, 2011 | 01:46 PM
blue line's Avatar
Thank you. I actually did a dumb thing, but it worked. Using an open-end 12mm wrench, I stuck a wad of good old fashion Bozoka Bubble gum, which stuck to that bolt like "super-glue" does to your fingers. I suspect the gum trick may have been used before, so I have no vision of filling a patent for a 12mm open end craftsmen wil a bubble gum insert.
Old Jul 21, 2011 | 02:47 PM
Krimson_Cardnal's Avatar
dumb is as dumb does if it works it isn't dumb but creative - good job blue +reps to you
Old Jul 21, 2011 | 02:56 PM
mahout's Avatar
You're right it has been used before. Even our mechs have tried too but wasn't very successful because oily wrenches don't stick well with gum we had. Yours must be really good stuff but I'm not sure I'd want to chew it; my teeth are old but not not false and I don't want them to be either.
Good show. glad it worked. Ain't creativity wonderful.
Giovanny Alan Alvarado
Apr 27, 2025 01:09 AM
jilm
Apr 13, 2016 06:22 PM
running
Oct 26, 2012 12:20 PM
jim beam
May 4, 2005 11:16 AM
justinreigle (at) gmail (dot) com
