Fog outside the windshield
Old Jul 24, 2011 | 01:17 PM
Vince_TB's Avatar
When it's super humid outside this happens whether or not the A/C is on:
If I set the flow of air on the windshield, it becomes foggy outside and I have to use the wipers almost every 30 seconds to clear it .
BUT, if I set the flow of air elsewhere, for example, at my face, it becomes foggy INSIDE the windshield and I have set back the flow of air on the windshield and the catch 22 goes on and on....
Help?
Old Jul 24, 2011 | 03:20 PM
Subie's Avatar
Question: When you said "set the flow of air on the windshield", do you mean your switch is on "Defrost" and if so is your air circ set for circ (outside air coming in) or recirc (air recirculated inside? It's recommended in most cars to set the air to circ when using AC or Defrost. Also, does this happen regardless of the temp outside?
Old Jul 24, 2011 | 04:29 PM
Vince_TB's Avatar
Yeah i meant defrost and i was set for circ.
And it only happens when it's super humid outside, like just after a thunderstorm.
Thanks
Old Jul 24, 2011 | 04:35 PM
Texas Coyote's Avatar
I have had the same thing happen but only a couple of times... It is like the way water condenses on the outside of a glass of cold water..
Old Jul 24, 2011 | 06:27 PM
Subie's Avatar
Thanks
I think that's normal operation Vince, specially when super humid. The car's condenser unit turns on when in AC and/or Defrost mode trying to blow dry air into the cabin.
So your fog inside or outside the windshield depends on whether you're in AC and/or Defrost mode (fog outside). When in neither mode, fog inside.
Old Jul 25, 2011 | 12:25 PM
mahout's Avatar
Thanks
When the windshield is cooled by the A/C vents water in high humidity outside air will condense on the windshield. mother nature makes it that way on purpose. It can happen on side and rear windows as well even without cool air blowing on it, just cool air in the cabin.
TommyMadison
Oct 13, 2014 12:25 AM
Justyna
Nov 27, 2009 03:55 PM
willmax11
Canada Fit Forums & Clubs
Jan 12, 2009 04:13 PM
pb and h
Sep 18, 2008 03:56 PM
sLiVeRwOrM
Jul 8, 2006 03:40 AM
