Both fog light not working, not fuse, advice?
Old Sep 9, 2011 | 11:19 AM
omygod711's Avatar
So i notice my 08 fit sport's fog lights are both out one day. I think it is kind of weird for both light bulb to go out at once. I check the fuse and it is good. The indicator on my dash do light up when I flip the switch. There is voltage at the fuse terminal.
I hesitant to try to check the bulbs because it's a chore to get it off from what I read (remove bumper I think).
Can it be the relay etc?
Thanks
Old Sep 9, 2011 | 02:31 PM
Subie's Avatar
Not familiar with the wiring harness if there's an extra relay somewhere. But first the obvious, how did you check the fuse? Visual? Meter? Sometimes they look good but are electrically open. Was it the right fuse you checked? Just simple rechecks... If the fuse is blown, I would swap it with like fuse and recheck the lights. Just me.
If all the obvious have been covered, then you'll have to check the bulbs. Bad bulbs have also been known to short out the circuit. Good luck!
Old Sep 9, 2011 | 02:43 PM
omygod711's Avatar
I have a fuse checker and it returned "ok".
I think I have to check the bulbs...
Is there any trick to get it off or I have to take the bumper off?
Old Sep 9, 2011 | 02:50 PM
Subie's Avatar
Sorry, haven't done it yet and don't have the car right now to look. But look around the forum... The DIY area.
Old Sep 9, 2011 | 03:36 PM
Krimson_Cardnal's Avatar
#1 fuse 7.5A, #9 fuse 20A, #22 fuse 7.5A, #60 fuse 50A
Check em all.
As far as getting to the fog bulbs - housing is held on w/ 2screws. Simply remove them.
Old Sep 9, 2011 | 04:34 PM
Dean's Avatar
only reason to removing the front bumper is when you are installing OEM fogs on your Fit that was not equipped from factory with them?
After the fogs are installed, there are two screws per side. Once the screws are out, pull forward and out as to release it from the bumper. It has tabs holding it in on that side.
Really simple process actually.
Old Sep 9, 2011 | 05:33 PM
omygod711's Avatar
Thanks, you guys are right about the screws. Do I just pull hard to remove the fog from the wire? Feels tight, don't want to break it. Is there any taps holding the bulbs? I can't pull the fog light all the way out, only enough so I can put my hand in there and attempt to pull the bulb out.
Old Jul 9, 2013 | 10:39 AM
WillB's Avatar
Check em all.
Are all these fuses related to fog lights not working? 07 Fit has the same issue.
Worked when we left the house, quit on the highway.
Where is the fuse panel located?
Old Jul 9, 2013 | 04:54 PM
WillB's Avatar
Update: fuse for fogs was nliqn, #21.
Old Jul 11, 2013 | 06:45 PM
lakia5524's Avatar
fog light
also check your option fuse under the hood I think its a 30 I have a picture with notes on my profile file if you click it worth a try ....
Old Mar 13, 2019 | 07:03 PM
knope's Avatar
lol apololgies, as edit note states intended to post joke here https://www.fitfreak.net/forums/3rd-generation-2015/100127-radar-not-working.html#post1425216
Last edited by knope; Mar 13, 2019 at 07:06 PM. Reason: Message in wrong thread of multiple tabs
oneder101
Jun 15, 2015 05:03 AM
Mister Coffee
Apr 3, 2015 10:35 AM
battouter
Oct 11, 2013 02:05 AM
Gabybeba
Jun 11, 2013 05:07 AM
samson2112
Oct 22, 2010 07:59 PM
