Not fully satisfied with my Megan Coilover drop
Old Feb 26, 2012 | 05:57 PM
J-GD3's Avatar
I want to lower the front just a bit more. I set the preload and lowered it to the max and still have about 2 finger wheel gap.
IMG_0024-1.jpg?t=1330295803
Old Feb 26, 2012 | 06:29 PM
dustinb's Avatar
Are you sure you are doing it correctly? You are threading the bottom portion of the coil right?
Old Feb 26, 2012 | 07:10 PM
J-GD3's Avatar
yea. I locked the 2 rings where I set the preload and I loosened the third ring to twist the whole threads/coil into the strut. That's the max drop I can get from the Megans for the front. It dropped a very tiny bit more after the suspension settled though.
Old Feb 28, 2012 | 02:33 PM
n00b_stat's Avatar
im on the megans as well, and it's unfortunate that this is as low as we can go. well, as far as the brand is concerned. i do wish i could tuck tire on the megans though... oh well.
Old Feb 28, 2012 | 02:43 PM
Wanderer.'s Avatar
Get bigger wheels, problem solved.
Old Mar 12, 2012 | 04:55 AM
craigquakertown's Avatar
just watch for wheel rub on your wheel well it can destroy tires be safe pothole can be the enemy to depending on where you live and bottoming out in parking lots be safe used to work in a tire shop cars came in with lowering kits some i was wondering how they held together from the scraping
Old Mar 12, 2012 | 05:13 AM
DreaMv's Avatar
u can take out the locking collars and only keep the one holding up the spring for the front!
limedaiquar
3rd Generation GK Specific Suspension & Brakes Sub-Forum
16
Sep 7, 2018 06:47 AM
SROFOO
Jan 29, 2013 12:21 PM
ELGE8
18
Dec 11, 2010 04:09 PM
MiniMeRR
64
Dec 25, 2008 05:07 PM
dickiez
May 30, 2008 08:23 PM
