People with hood dampers. HELP!
Old Apr 9, 2012 | 12:30 AM
T-Fit's Avatar
I finally got around to installing my JDM hood hinge to bolt my damper on. First thing I'm gonna say is it's an easy job, but a total pain in the ass. I think it'll be worth it in the end though.
Anyway. I got everything on, bolted up my damper and the hood wouldn't close. I looked for a second, scratched my head then lowered it while peeking under.... The damper is landing directly ON TOP OF THE FUSE BOX!
Anyone else had this problem. I got dark so I gotta check it out some more after work tomorrow.
If this all fails... Anyone got a JDM shorty prop rod?
Old Apr 9, 2012 | 10:31 AM
MNfit's Avatar
Do you have the T1R hood dampener or did you make your own? I have the T1R one and had no problems with it hitting the fuse box.
Old Apr 9, 2012 | 10:25 PM
T-Fit's Avatar
Yes, it is the T1R kit. I just checked it out again and can not get it to work. I get it about 6" from being closed and it hits the fuse box.
Old Apr 9, 2012 | 11:14 PM
MNfit's Avatar
I can take some pics in the morning how I have mine all mounted up if that helps. Maybe you will have to relocate the fuse box?
Old Apr 9, 2012 | 11:24 PM
T-Fit's Avatar
Here are some pics of mine. Can't figure out what I've done wrong.
T1R pic from the site.
Mine installed.
This is as far as I can close the hood.
Old Apr 10, 2012 | 03:38 AM
fitster's Avatar
try reversing the shock?
Old Apr 10, 2012 | 08:17 AM
MNfit's Avatar
its mounted just like mine is. How far is the hood going before it stops?
Old Apr 10, 2012 | 10:07 AM
T-Fit's Avatar
In my third pic the shock is touching the box. There's still about 6-8 inches to go for it to close. I may have to stop by A&J and see whats up.
roksta
Sep 17, 2023 09:41 AM
hnickm
Nov 28, 2015 08:29 PM
POS-Fit
Jul 23, 2015 04:17 PM
Ritzbury
Oct 17, 2007 01:26 PM
kyo2529
Oct 2, 2007 01:37 AM
