Is my Fit hydrolocked?
Old 06-29-2012, 10:00 AM
joeykunz's Avatar
I sucked water out of all the cylinders with a long tube and syringe, got some out of each one. Let dry and bake yesterday. Last night cranked it and it turned over ok, reinstalled same plugs to test. Had to jump the batter to full life, cranked for about 20 seconds and it started up. Held idle ok no noises yet. Shut it down and getting fresh oil and filter in.. So far so good.. I'll check compression later and if that is ok then I assume it's ok at that point.
Old 06-29-2012, 12:49 PM
Subie's Avatar
Originally Posted by burningwrek
Well it's toast. I did everything I said I would, gave it a crank and it sounded like a hammer against metal. I filed a claim with my insurance today so hopefully they'll help me out. Learn from my lesson, fellow fit freaks. Avoid standing water.
So all this was because you had CAI? Joey too?
Old 06-29-2012, 05:37 PM
Texas Coyote's Avatar
I'd see about getting a couple of gallons of methanol or ethanol to put in the crankcase and cylinders too absorb the water in the oil system and cylinders before adding oil.... Using an air compressor to blow out water and then the alcohol with remaining water could save you from having problems later on...
Old 06-29-2012, 08:11 PM
joeykunz's Avatar
Yes cai with wife driving. So everything is ok, compression was over 230 for each cylinder, flushed with 2 oil changes, 2 filters, no more milky oil. Fresh synthetic and new plugs, runs like normal again. I split the intake so the cone is under the hood now, no more cold part. If you have a CAI get rid of it, wife said it happened in maybe 3 inches of water.
Old 06-29-2012, 08:36 PM
Subie's Avatar
@joeykunz, never liked CAI unless you're a tracker w turbo for those reasons... They're mostly looks. Just my take... Good to know you're able to correct your issue...
Old 06-30-2012, 01:37 AM
I had an AEM CAI for awhile that was damaged by a road hazard... I removed the lower pipe and put a huge Spectre filter on it and had a much safer and more free flowing SRI type intake... The Spectre filter is still in use on the intake pipe to the supercharger and the additional air flow could be felt immediately and still is after 5 years... It is very low pitched but loud...
Old 06-30-2012, 01:59 PM
mahout's Avatar
Terrific !!! I think you're OK too.
Now change oil and filter after 15-25 miles then again at 500 miles; then you can go to Honda schedule. Its the water in the oil that will do the most damage later.
Note to others with CAI : the closer to the ground that your intake sucks air into the engine the hotter your intake air will be. While thats good for mpg its not so good for power and as these posts have shown, sucking water into the intake is never good.,
Old 06-30-2012, 02:09 PM
fit[vivian]'s Avatar
Glad you corrected your issue~ and i'm happy i decided not to take my fit out during the storm because we got stuck in traffic with about a foot of water on 3rd.
wenzu1989
06-27-2016 10:35 AM
Soon2015FitWillBeMine
06-17-2015 09:52 AM
jdmekh22
02-06-2015 03:15 PM
houstoncc
09-30-2010 10:39 PM
legacymonkey
01-28-2010 07:44 PM
Quick Reply: Is my Fit hydrolocked?
