Got this purple Fitty 08', what should i do now?
Old Jul 17, 2012 | 04:36 PM
purplekush's Avatar
Hi guys, i bought this purple fit 08' M/T few moths ago,
i decided to put some modification on my baby.
First i want to get JDM taillights
I heard people have trouble with installing it by themselves.
Second thing is is want to get some new rims
maybe 205/40/17 or 195/45/16
anyways, i have some concerns.
if i put 17inch rims on it, would it rub?
or should i do something with the suspension first.
just to make the ride stiffer. but tbh i dun want to lower it
And third i want to get a new exhaust system.
I want some performance but not too loud,
i dun want to get pulled over anymore
way toooo many tickets already LOL
Old Jul 17, 2012 | 07:54 PM
Hootie's Avatar
Hello...
First of all and if memory serves me right, the JDM tail lights are a semi-direct fit for the GD. Only reason I say semi, is the wiring harness may have to be "tugged" or "pulled" more just so the connectors can reach to the tail lights. Again, that's going by memory from what I've read here on the forum.
Secondly, in my honest opinion I'd run a 16x7 wheel with an offset between +42 to +45 or higher with 205/45R16 tires. Running 205/40R17s on a 17 inch wheel leaves very little sidewall to absorb the initial shock from bumps and doesn't protect the wheel as well due to having a thinner side wall than the 205/45R16 (again in my opinion). Offset (in combination of wheel width and tire size) is more of a factor in the case of tire rub.
Run a 205 tire on a wheel with an offset of +40 you could possibly rub at stock height with a load in the back... Run it on a wheel with an offset of +35 you will more than likely rub since the wheel is pushed 5mm away from the car's center line.
Thirdly (Is that even a word?), if you want to change up the feel of the suspension there are lowering springs out there that offer a fairly minimal drop such as Swift, Progress, and Tanabe (their GF210s) but the car will be lowered a minimum of 1 inch up front and up to 1.5 in back depending on the spring you go with out of those three for a fair price. If you want to retain stockish height but still change a stiffer ride, get coil overs. Their not cheap but depending on their spring and damper rates, can stiffen up the ride.
Fourthly, if you're looking for a subtle exhaust check out Honda's HFP muffler offered for our GD chassis Fit or Tanabe's Medallion exhaust. Both are very quiet for an axle back when cruising and have a nice exhaust note when in the throttle... they do not produce a raspy exhaust much like most people's Pepboy's/Autozone special muffler.
As for what to do first, its your car... You choose what you want to do and whatever you feel that you need to do since you're the one that will likely be paying for it and living/driving with it. All we can do is really provide incite. ^.^ Hope this helps.
Old Jul 17, 2012 | 08:18 PM
MNfit's Avatar
*EDIT* goddamn it, ok links are still not working, for the tailight DIY check my sig, it has a link *EDIT*
Taillights, here is a DIY
https://www.fitfreak.net/forums/fit-...light-diy.html
wheels, look at this subsection
Fit Shoes - Unofficial Honda FIT Forums
and here is two threads to start with to get you started
https://www.fitfreak.net/forums/fit-...-included.html
https://www.fitfreak.net/forums/fit-...s-answers.html
as for exhaust make your way to this subsection
Fit Exhaust Systems - Unofficial Honda FIT Forums
and look at this thread https://www.fitfreak.net/forums/fit-...os-inside.html
Old Jul 18, 2012 | 03:48 AM
Suzi_q's Avatar
Ah, I love the colour, congratulations!
I installed my LED tail lights myself, took longer than I thought with a little hit and miss here and there, but we got it done and had no issues.
I can relate to getting too many tickets too ....
Old Jul 18, 2012 | 03:49 PM
purplekush's Avatar
hey guys!!! thanks for the information!!!!
really appreciate it!!
i think first thing im gonna do for this fitty is JDM taillights
i got some hook ups here to get them cheap
let me see the outcome
just cant wait;p
and yaa purple is the way to beee
Fit4Trav
Apr 15, 2013 01:13 PM
overheatedfit
Oct 19, 2009 02:49 AM
Syco54645
Jan 12, 2009 07:24 PM
tommyinsane
Jun 10, 2008 11:47 PM
aceshigh87
Mar 20, 2008 12:03 AM
