HELP! How to lower my rear coilovers?
I think they are on the lowest setting at the moment, but have any of you modded this set up and made the rear lower?
Comments are welcome thank you people
You could see if you could remove the adjustment collars somehow. That'd give you about an extra inch it looks like?
I think taking the whole perch out would drop it more than "a little bit" that looks like about 3" haha. If you wanted to go LOW LOW that would probably be how to do it in the back though.
Honestly, the rear suspension in this car is the easiest you can get. You just remove the bottom shock bolt (maybe you are tightening too tight) and the whole thing drops down. Also I'm not sure if you are aware, but make sure you adjust your shocks for the amount of spring drop you are putting in. The manufacturer will have specs for what type of sag you should have on the shock.
I know its the easiest ut the bolt is always too tight without using a impact tool on it. I didnt tighten it last, i took it to a garage last time. But to be honest i havnt messed with the back since.
The garage is going to cut about 20mm of the black thing which the springs sits in.
Fitfreak07
22
Jul 14, 2011 08:44 PM
