Coils
Old Jan 2, 2013 | 08:42 PM
heuhus's Avatar
Coils
Hello,
I have a 08 Sport with 208k miles. Having trouble with repeated failures of coil on #1 cylinder. Replaced it twice within last two months. I drive about 5k a month. I used iridium plugs and dialectric grease. I do run regular gas, premium would kill me! Car has been great otherwise. I did recently have the valves adjusted. Probably didn't need the coils/plugs, but changed at 100k interval out of habit. Any suggestions will be appreciated! Thanks!
Old Jan 5, 2013 | 01:55 PM
JCLW's Avatar
How does it fail? Just stops working or physical damage?
After one month does it still look like new?
What happens if you swap it with one from another cylinder?
Old Jan 8, 2013 | 08:26 AM
heuhus's Avatar
coil
Coil still looks like new, just stops working. Number one cylinder has had two failed coils in last 10k miles. Thought it was due to cheap parts, but may be another cause. I did not see anything unusual in plug hole, but did not have a mirror handy. Plug seems ok.
Old Jan 8, 2013 | 11:40 AM
TPColgett's Avatar
There are really a ton of threads on here regarding coil/plug/valve adjust issues. If I recall correctly, one coil going bad can cause additional drops in voltage in the other coils causing premature wear. Try swapping it over onto another cylinder. It may end up you need to replace all 4 not just the one failing...
Old Jan 8, 2013 | 12:41 PM
mahout's Avatar
Originally Posted by heuhus
Hello,
For the two hundredth twenty seventh time?
Fits are not maintence free; they do require at least new plugs and coil. First, change gas supplier and add a can of injector cleaner paks about every 50,000 miles. Do the cheap and eassy things first.
1. Take your Fit to a aftermarket autoparts store like AutoZone, Oreilly's, or Discount uto parts and most will check your OBDII codes for free. Replace the bads parts.
2. If thats not getting codes for faults replace the spark plugs tho you should have gotten code for plugs.
3. reset valve clearances.
4. Have ECU and emissions devices like EGR valve checked.
JCasey
Feb 13, 2019 06:27 PM
frethack
Aug 13, 2017 04:28 PM
Kegel81
Jan 22, 2017 10:12 AM
craigquakertown
Oct 28, 2015 01:47 PM
wackyflik
Sep 22, 2014 09:39 AM
