Help! cel after valve clearance adjusment
Old Jan 12, 2013 | 08:31 PM
willy65000's Avatar
Hey folks. Just finished my 3rd valve clearance adjustment on my 07 (130k) and it went off without a hitch as usual. That is until I started the car and immediately saw that I had a cel. All hoses and connectors are plugged in as they should be. The only thing that I can think of that I did differently this time was not having disconnected my negative battery cable at all. Could this be my problem?
Bill
Old Jan 12, 2013 | 09:27 PM
accordguyintake's Avatar
Do you know what code it is?
Old Jan 12, 2013 | 10:17 PM
Hootie's Avatar
^^ X2 on this and double check all your connections.
Old Jan 13, 2013 | 12:25 AM
willy65000's Avatar
Don't know the code yet as I don't have a reader. Disconnected the negative for a while and then drove the car after reconnecting it. No cel as of yet. will see how things go and get a code if it returns.
Thanks,
Bill
Old Jan 13, 2013 | 06:44 PM
Carbuff2's Avatar
I'm a bold risk-taker, living my life "on the edge"...so I don't disconnect my battery before a valve lash adjustment.
Haven't had a CEL yet.
(Last time I cleaned the throttle-body on the V, however, I forgot to reconnect one electrical plug. My ScanGauge could not reset the code, either...had to wait many drive cycles for it to go away. )
Old Jan 14, 2013 | 11:10 AM
willy65000's Avatar
I almost always disconnect the negative after having dropped a wrench on someones starter years ago and having the wrench hit the positive starter lead with one end and ground out on the other end. It wasn't a pretty sight. The wrench turned red hot and his battery was bulging. Believe it or not, All he needed after that was a new battery.
Any way, Disconnecting the negative cable was just a last ditch attempt as getting rid of my cel. I can't figure out why it would make a difference either but it seems to have fixed my problem for now. The other thing I did was disconnect and reconnect all of the electrical plugs that I had messed with for the valve adjustment.
Old Jan 14, 2013 | 11:18 AM
TPColgett's Avatar
That is odd.... You should still throw a reader on it to pull the stored codes and see what it was!
Old Jan 14, 2013 | 12:55 PM
willy65000's Avatar
Just returned from Autozone and there was no code stored. I guess it's now safe to assume that all codes are cleared after having the battery disconnected for a period of time.
Arcturus
Nov 19, 2017 06:57 PM
codenamezero
Sep 21, 2016 08:23 AM
Cara OConner
Feb 21, 2016 10:31 AM
heuhus
Feb 12, 2015 09:38 AM
abgenre
Aug 22, 2013 11:52 AM
