Engine Problems... Any Ideas?
Old Aug 22, 2013 | 11:02 AM
abgenre's Avatar
Ok folks, my 09 fit is acting up. It has 150K miles and has been lagging on me lately. When I take off from a stop, it seems to not want to go. Like I put my foot to the floor and there is a delay of power for about 1 maybe 2 seconds. This is a lot of time when you are pulling into traffic.
Once I am moving, no issues. Climbs to 80mph no problem. passing on the interstate is not an issue.
I know it needs a valve adjustment, but could that be the issue at all?
Old Aug 22, 2013 | 11:07 AM
Schoat333's Avatar
Sounds like a sensor. It could be quite a wide range of things, but my first guess would be a bad Mass ari flow sensor. Start with testing that.
If the MAF is good, check the throttle body to see if its sticking, or moving slowly.
*edit
It is probably also throwing a trouble code, even if the CEL is not on yet. Might be worth having it hooked to a code scanner.
Old Aug 22, 2013 | 11:39 AM
Steve244's Avatar
It was due for valve adjustment at 100K. This very well could be part of the problem.
How about spark plugs?
Old Aug 22, 2013 | 11:52 AM
abgenre's Avatar
Thanks for the ideas... planning on doing a valve adjust this weekend. I changed the plugs and 1 coil pack about 20,000 miles ago. Looks like to do the valve adjust I have to remove the throttle body and Air flow sensor so I will check those and clean what I can. Throw in a new air filter while I'm at it.
Steven Hung
16
Feb 17, 2019 03:42 AM
heuhus
Feb 12, 2015 09:38 AM
Myxalplyx
Dec 12, 2014 02:18 PM
geepondy
May 23, 2013 11:19 PM
willy65000
Jan 14, 2013 12:55 PM
