How Do I Replace Gear Shift Boot on a Jazz?
Old May 14, 2013 | 05:38 PM
donaidh's Avatar
Hi,
Just got a 2003 Jazz 1.4 SE. The rubber gear shift boot / gaiter is all torn so I have a nice new leather one.
How do I remove the silver ring around the gear shift? Do I need to remove the whole center console?
thanks!
Donaidh
Old May 14, 2013 | 09:30 PM
JHHjr's Avatar
Yes, remove center console....
Unscrew shift knob; Then 2 skews in the back, then 2 clips in the front (both driver and passenger sides), then remove console. Flip over and you'll see the boot ring held by three screws; Remove and install new boot--reverse the above an you should be good to go. GOOD LUCK!
Old May 15, 2013 | 03:34 AM
loudbang's Avatar
And there is a "pop in clip" under the console that you can feel resisting pulling up on the console. Just so you know to expect it ...it's not stuck just that clip holding it to the floor. Just keep pulling until it pops out.
And make it the first thing you pop back into place when you put the console back down where it goes.
Old May 15, 2013 | 03:58 AM
donaidh's Avatar
Excellent, thanks for great replies! Will tackle this tonight. Sounds straightforward now that I have the knowledge. Thanks again!
413FitMurtz
Jan 30, 2016 11:35 AM
cajunpedaler
Oct 20, 2015 03:42 PM
SilverEX15
May 22, 2015 09:57 PM
tobey457
Dec 3, 2008 07:00 PM
phil_qc
Jun 24, 2006 11:07 AM
