DIY oil change and MM codes
Old Jun 2, 2013 | 02:08 PM
MTLian's Avatar
Hello. I do my own oil changes and fluid changes. Last time I did my oil change, I did it at 20 pr 30% oil life on the maintenance minder. After, I reset the MM to display 100%. However, my limited understanding of the MM tells me that only at 15% or less oil life, the MM wil give me the maintenance codes related to my car. Does that mean that I have to let the oil life drop to 15% every time to get the maintenance codes? If so, Is there anyway to know the maintenance code before at above 15% before resetting the oil life?
Thanks for clearing this up for me.
Old Jun 2, 2013 | 02:34 PM
DrewE's Avatar
There is a way to get it to display the upcoming code beforehand; the details should be in the owner's manual. Off the top of my head, I think it involved holding the mpg-o-meter selecto button in for a few seconds while on the oil life remaining page with the oil life between 50% and 15%...but my memory may well be faulty on the details.
Old Jun 4, 2013 | 02:57 AM
MTLian's Avatar
That might be it but its definitely not in the manual. Does anyone know?
Anyway, I just got down to 15% and I got an a 2 which I believe is oil + filter. Does anyone really just change the oil and not the filter? I figure a filter is only 5$, why not change it every time?
Old Jun 4, 2013 | 04:05 AM
Subie's Avatar
No way I'd change oil and skimp on the filter. But that's just me. What does your gut instinct say?
Here's some more reading stuff on the MM: https://www.fitfreak.net/forums/fit-...ce-so-far.html
Jensen Healy
Aug 2, 2017 12:59 PM
spryter
Apr 14, 2014 08:50 AM
flipperlazo
Oct 12, 2011 04:06 PM
Bounty Hunter
Feb 20, 2007 02:00 PM
KRAFTYDIN
Toronto Community
Nov 11, 2006 01:03 PM
