Tire numbers
Old Aug 26, 2013 | 10:58 AM
Realguy921's Avatar
Tire numbers
Hi all. My tire pressure idiot light is on and I know I need to replace the sensor in the tire. The read out only says tire #1. Which tire is that?
Old Aug 26, 2013 | 01:01 PM
13fit's Avatar
Honda TPMS systems do NOT recognize tire location
You will have to get a scanner that reads the signal, and then simply lower or raise tire pressure on each sensor to verify its the bad one.
Sensors are 20-50 bucks each depending on where you get them
Old Aug 26, 2013 | 01:06 PM
Realguy921's Avatar
Re tire # 1
Thanks, I found someone with one. Turned out two senors weren't working.
Old Aug 26, 2013 | 02:46 PM
Hootie's Avatar
Originally Posted by 13fit
The Fit's TPMS systems do NOT recognize tire location.
Fixed that first line for ya.
Tire pressure isn't too critical during the inspection of the sensors since you'll be inspecting for sensor functionality; so, long as the tire pressure is above the pressure threshold (27 PSI on most Fits) you should be ok in most cases.
The reason I say "most cases" is due to occasionally having a tire sensor experiencing intermittent failure... They usually check out "ok" on the sensor scan tool when checking for battery life and functionality but you will notice that the tire pressure is drastically off (usually 4 to 7 PSI from what I've seen) from its actual pressure (which is commonly seen with Fix-A-Flat is used).
Frylock017
Aug 4, 2018 08:03 AM
Brianflys
Jun 23, 2014 08:02 PM
grimm79
Jan 28, 2011 07:48 PM
stockrex
Aug 30, 2010 12:24 PM
Len1
Sep 11, 2009 07:17 PM
