Brake Pad Identification Help
Old Sep 16, 2013 | 10:51 PM
HondaPenguin's Avatar
I need help figuring out what brakes to order. It's on a 2008 Fit Ex (Mexican model). I figured it would use the same brake pads as the US models, but I was wrong like everything else on it. I'm hoping there might be another model or year that uses these.
Old Oct 9, 2013 | 09:01 PM
I did some research and found there is no equivalent US model brake pad after market or OEM.
I don't like the idea of importing expensive, stock pads from Mexico, so I'm looking at swapping this setup for US stock if it can be had cheaply or upgrading to type-r calipers; something along those lines. Suggestions are welcome. Also, I need to get a picture of the mounting bracket to confirm the US caliper, bracket and rotor will swap over with little or no modification. If I can get someone to confirm the bracket mounting after I get a picture of it up, I would greatly appreciate it.
ak753951
Nov 6, 2013 12:36 AM
Gregg
Oct 7, 2013 01:19 PM
nukeme70
Jun 28, 2013 05:43 AM
lilcat
May 5, 2009 01:00 PM
SennaVsProst
23
Feb 8, 2008 04:33 PM
