scraping sound near left wheel
Old Oct 16, 2013 | 05:18 PM
hqly's Avatar
I have an 2007 fit and i started hearing this scraping sound near the left wheel area at low speed.. when i'm in traffic. The sound has gradually gotten worst and i hear it even on the freeway now. My friend will take a look at it next month. Does anyone know what might be the problem? It sounds liek something is rrubbing against the rims as the wheel spins. The sound goes away when I brake then starts again when i take my foot off the brake.
Old Oct 16, 2013 | 05:22 PM
Triskelion's Avatar
A rock trapped between the brake rotor and sheet metal shield.
https://www.fitfreak.net/forums/2nd-...or-shield.html
Old Oct 16, 2013 | 09:20 PM
2010FitSport's Avatar
Agreed that it could be a rock.
It might be a good idea to get it looked at before next month if you can just to make sure it is only a rock.
Old Oct 17, 2013 | 02:54 AM
loudbang's Avatar
More likely a bad wheel bearing. GD have had this problem for a long time. There is a "hidden warranty" for them but not sure if a 2007 will still qualify.
OR your brake pads are worn down to replace thickness and pad indicator is dragging.
Old Oct 17, 2013 | 10:41 AM
mahout's Avatar
Check thefender liner hasn't loosened and rubbing against the tire when it flexes with changes in speed or direction. If you are lowered of have wider tires it may not have to be loose.
good luck.
ps its a fairly common problem with todays plastic parts assembly techniques.
In the instances we have found debris in the caiper and back plate the sound got worse with braking. And when you brake the wheels get more camber due to spring compression and that would cause the top of the tire to move inward away from the fender. Just a thought. If that is it you will definitely see rub marks on the liner.
Old Oct 18, 2013 | 10:46 PM
silverback's Avatar
How much brake pad you have left? Sometimes the warning noise goes away when you
brake. Dont drive too far before you figure it out. Pads are cheap-rotors not so much...
Old Oct 25, 2013 | 10:47 AM
silverback's Avatar
HGLY: What did you find out? Your solution may help other "Freaks"
Old Nov 2, 2013 | 03:49 AM
BlueCell's Avatar
Most likely the rear bearings. Mine were making noise recently, I just took it out and regreased it. No more noise. Those who say they are sealed bearings, well....they come apart, just add more grease for the cheap fix.
jjcentral
Oct 4, 2014 06:25 AM
Tralfamadorian
Dec 30, 2013 02:40 PM
Blackbeard
Jul 27, 2011 12:50 PM
Halcyon
Mar 15, 2010 11:04 PM
Alex
May 4, 2005 11:16 AM
