Any ideas? Help?
Old Jan 31, 2014 | 02:47 AM
Nayellow's Avatar
Red face Any ideas? Help?
So I have a 08 honda fit and it's been jerking a lot, anyways my car was in drive and the light turned green so I was about to hit the gas and my car started jerking even more that it just stalled/shut off. Any ideas of what it might be? Glad it stalled because some lady cut me off too!
Old Jan 31, 2014 | 03:41 AM
glens67's Avatar
More information is needed. Automatic transmission or manual? Mileage? Maintenance/service up to date?
Old Jan 31, 2014 | 03:58 AM
derykisonder's Avatar
Sounds like you didn't warm up your car for a while.
You might want to get your values adjusted, I had the same issue and it went away from getting the values adjusted
Old Jan 31, 2014 | 04:57 AM
glens67's Avatar
Their VALVES, NOT VALUES.....
Old Jan 31, 2014 | 10:00 AM
DrewE's Avatar
The OP said it was in drive, so it's an automatic. I do agree that more detailed info is better, of course.
It sounds as though the engine is hesitating or missing, which is typically either valves needing adjustment, or spark plugs and/or coil packs needing replacement, or possibly both. There are other possibilities, of course, but those seem to be the most common from what I've seen here.
If the check engine light is on, getting the codes that are set in the computer might be really helpful in diagnosing the problem.
If the engine is running perfectly but the car still jerks and clunks, I'd take a good hard look at the motor mounts.
Old Jan 31, 2014 | 10:28 AM
Nayellow's Avatar
It's a standard transmission and it has about 78,000 miles. I'm taking it in for an oil change as we speak. Thanks for the info!(:
Old Jan 31, 2014 | 10:53 AM
palos's Avatar
They are valves or they're valves, not their.
Old Jan 31, 2014 | 12:20 PM
2poler's Avatar
Old Jan 31, 2014 | 12:24 PM
Nayellow's Avatar
Honda dealership said it might be the transmission fluids. They said it's really dirty so hopefully that works!
Old Jan 31, 2014 | 04:13 PM
Carbuff2's Avatar
I doubt it.
Still, the manual tranny fluid needs to be replaced about every 30,000 miles to replenish the friction modifiers that allow the synchronizers to work well.
So go ahead, "Git 'Er Done". Shifting will be easier...
I, too, vote for having a valve adjustment done...
If you mean "The clutch judders" that's a whole different ball game. Look here:
What makes a clutch judder
Our '07 occasionally judders a little, on cold mornings.
Old Jan 31, 2014 | 07:22 PM
jmsplitfyre's Avatar
Valve adjustment or coil packs. 78k miles should be due for an adjustment anyway.
Old Feb 3, 2014 | 01:18 AM
breadtrk's Avatar
Coils packs, they are notorious for being crappy. Probably not valves, at worst they will clatter, they can't really cause stuttering or stalling unless they are damaged, then no amount of adjusting will help that.
Unless you are in the artic with -20 below temps it is start and drive car.
Old Feb 3, 2014 | 07:15 PM
Carbuff2's Avatar
Beg to differ.
A LOOSE valve will clatter. BUT the exhaust valves TIGHTEN until the won't open. That's the Silent Killer.
When setting valves, I always go for the loose end of spec. Yeah, the valve noise is somewhat audible, but it is music to my wallet's ears.
Old Feb 4, 2014 | 06:21 PM
mahout's Avatar
They are, or they're valves ... not their...
Sorry, couldn't resist.
Old Feb 4, 2014 | 07:03 PM
glens67's Avatar
OK it sounded right at the time
Glen
Fithyper
Jan 17, 2016 02:30 PM
cheanko
Dec 12, 2012 02:34 PM
ny111
Sep 6, 2010 11:44 PM
hqly
Jun 28, 2010 06:48 PM
FELIXY69
14
Oct 31, 2007 04:57 AM
