Car vibrate when switch on aircond and put in R gear
Old Mar 10, 2014 | 01:25 AM
wackyflik's Avatar
I have this problem for months and it does not solve yet. I changed the mounting already. Last Saturday send for aircond service and the mechanic said my flywheel caused the problem. I have this vibrate when I switch on the aircond. The vibrate a bit worse when I put in R gear and less vibrate if I put in D. Is it true flywheel can caused this vibration problem?
Old Mar 10, 2014 | 02:49 AM
ikutoisahobo's Avatar
Sounds like your engine's running weak. Why? I don't know, to be honest.
Old Mar 10, 2014 | 07:50 AM
13fit's Avatar
its probably something as simple as putting in fresh spark plugs.
or an engine/transmission mount is worn out.
Old Mar 10, 2014 | 08:03 AM
wackyflik's Avatar
actually just changed the mounting early of this year. but someone advised me to change to genuine honda mounting from japan. he said i might be unlucky to have imitation mounting installed on my gd.
Old Mar 10, 2014 | 10:45 AM
13fit's Avatar
Even if they are aftermarket, they should still work fine.
Are they ROCA brand? they are actually better then factory in terms of durability and movement control. They felt really good when I installed them into a Del Sol (my old all motor D15 build)
Are you getting any check engine lights? These Fits are ridiculously sensitive to misfires, and will let you know if they are present.
If not, I would wager the problem is just an old set of sparkplugs that need to be replaced.
Has your gas mileage been effected at all since you first felt the vibrations??
2012FitFan
Jan 9, 2020 08:06 AM
cwidener123
Mar 27, 2017 12:33 PM
timmcd
Jan 6, 2015 12:46 PM
StormSurfer
Jul 25, 2011 02:05 PM
gcisko
Jun 28, 2006 03:15 PM
