brake light
Old Mar 11, 2014 | 07:32 PM
UnicycleWheelie's Avatar
brake light
Is there any way to mod or turn the middle brake light into a LED one?
Old Mar 11, 2014 | 08:10 PM
HB1320's Avatar
I've seen it done but it won't ever turn out like an authentic one. I'm not trying to stop you just want to let you know that the OEM led one is extremely bright
Old Mar 11, 2014 | 09:15 PM
Alright thanks
Old Mar 11, 2014 | 10:21 PM
EightyFour's Avatar
I have the JDM LED 3rd brake light. I think it's a great addition that's relatively cheap and practical.
If you look around the classifieds you may be able to find one for cheap.
Old Mar 12, 2014 | 07:49 AM
Carbuff2's Avatar
There are also kits that make the center light flash or strobe when on...
Old Mar 13, 2014 | 10:37 PM
myfoxmystere's Avatar
Here's a site to order an LED bulb to replace the stock 7440 bulb in the third brake lamp: http://www.superbrightleds.com/morei...ty-15-led/794/
You'll need to order the red bulb for the best results. The backkup lamps also use the same bulb as the high mount brake lamp. Your signals use the 7440 amber lamps, though you can use red ones on the rear legally. You'll notice you can also get the 7443 Stop & Tail bulbs here as well. These are your best options.
Old Mar 13, 2014 | 11:48 PM
HB1320's Avatar
Originally Posted by EightyFour
I have the JDM LED 3rd brake light. I think it's a great addition that's relatively cheap and practical. If you look around the classifieds you may be able to find one for cheap.
Absolutely right! I picked mine up for $65 dollars from a member from japan "JDMISME" great guy and great communication!
GinoLicious
Jun 12, 2014 11:31 AM
mrski57
Nov 22, 2012 11:47 AM
rdlove
Nov 21, 2009 10:52 PM
Jujutzin
Apr 20, 2008 11:53 PM
07fitsport
Aug 12, 2007 02:16 PM
