engine shakes on cold start up.
Old Mar 23, 2014 | 01:27 PM
shivic's Avatar
when i first turn the car on. its shakes. when it warms up, its fine. does this sound normal or a mantenence issue arising?
thanks for your help
Old Mar 23, 2014 | 02:21 PM
derykisonder's Avatar
How long do you have to warm up the car?
Does your car die if you don't warm it up?
If it's around 5 to 10 minutes to warm up, then it's time for you to get your valves adjusted.
Old Mar 23, 2014 | 03:23 PM
ikutoisahobo's Avatar
I've always considered it normal. It goes away after like 2-3 minutes. Maybe less.
Old Mar 23, 2014 | 04:21 PM
Well if you want the engine to run smoothly, then warm it up for a few minutes. But after you start the car it'll die and that's the valves
Old Mar 24, 2014 | 10:29 AM
Edison Carasio's Avatar
My car is doing this. I plan on having the valve lash done soon. Its worse in cold weather. But if I start it and immediately try to drive off and then come to a stop sign before the engine reaches normal operating temp, it'll die. I can kick it into neutral if I have to stop and it'll level out.
Old Mar 26, 2014 | 10:38 PM
shivic's Avatar
thanks for the suggestions guys.
its only lasts for a couple minutes. never stalls. when it warms, it runs perfect.
none of my other cars have ever done this. they all rev higher until the iacv warms but they don't shake like chiwawaus
Old Mar 26, 2014 | 11:50 PM
Happens when you have a pint-sized 1.5L!
Old Mar 27, 2014 | 02:27 AM
kylerwho's Avatar
spoon fed
How many miles are on the fit? Torn mounts will only increase the problem as the fit ages.
Old Mar 30, 2014 | 01:55 PM
doctordoom's Avatar
Supervillain
Mine used to do that too, for like 30-50 seconds after a cold startup. I adjusted the valves and it would run smooth from the start.
You can wait for it to get bad enough that you do stall, or you can adjust it now and it'll run smooth from the start.
Moonshine
Feb 15, 2014 11:59 PM
jackson6644
Oct 11, 2013 10:04 PM
hteejus
Dec 8, 2012 10:03 PM
baris90
Jun 12, 2009 08:49 PM
hqly
Nov 19, 2008 09:09 AM
