hondata mobile
Old Mar 30, 2014 | 05:41 PM
bryzem's Avatar
hondata mobile
guys hold on to your flashpro
hondata mobile is coming up on Ios and android
check hondata website for more info
Old Mar 31, 2014 | 09:41 AM
hehn's Avatar
http://www.hondata.com/mobile.html
I guess I bought my flashpro way too early.
Old Mar 31, 2014 | 09:55 PM
Rollerboots666's Avatar
Sweet! I just ordered mine last week. They had to make me a freshie since they had none in stock.
Old Apr 1, 2014 | 09:54 AM
apexanimal's Avatar
so looks like you need the flash pro module then get this to be able to adjust from your iPhone/mobile...
Old Apr 3, 2014 | 12:38 PM
DWils's Avatar
Originally Posted by hehn
mobile.html
Sucks. Me too. I guess I should have waited eight years to start tuning my 2007 GD. Or at least after 12/03/2013 when Hondata started producing FlashPros for the GD with Bluetooth.
Old Apr 3, 2014 | 02:12 PM
You didn't get the memo!
Old Apr 9, 2014 | 01:03 AM
The app is awesome!!!
Old Apr 9, 2014 | 09:08 AM
apexanimal's Avatar
should try to get the kr under control
looks like a cool app
Old Apr 9, 2014 | 10:37 PM
Had the car tuned yesterday. The guy seemed like he dialed it in good. No clue on tuning myself. Got +11 WHP and 10 WTQ.
Old Apr 10, 2014 | 12:04 AM
KR is 5 at WOT. Where is it suppose to be at?
Old Apr 10, 2014 | 01:56 AM
kylerwho's Avatar
spoon fed
Here is what I have been doing. Run stock basemap and datalog 2nd and 3rd gear pulls along with some cruising under heavy load (highway cruise control uphill).
Then set your graphs up so you can see your knock count and knock retard happen. See when it is happening and the conditions creating it(to lean or to much timing)
Then compare that to your new tune to see when the knock events are occuring and adjust timing/fueling to try eliminate it.
Even on the stock tune I got knock events.
Also see if anything is vibrating cause that might cause false knock readings which kicks in knock retarder and a loss of power
Old Apr 10, 2014 | 09:45 AM
apexanimal's Avatar
^yup
ideally, you want kr to be 0 everywhere... but on many engines you'll get a couple points of knock at certain frequencies that you just can't get rid of...
easy to to determine if its tune or frequency related is to up the octane and see if it does the same thing... if it does, its frequency, if not, it's tune...
Old Apr 10, 2014 | 12:07 PM
Frequency? Like noise as in something rattling?
Yeah it seems 1st and 2nd gear even with a load are at 0 KR. From 3rd on as I increase throttle it will increase KR to max at 5*.
I recently switched to 91 octane (highest in CA) a few weeks before the tune. I'm gonna have to data log this and figure things out.
Old Apr 10, 2014 | 01:57 PM
Could a colder plug help this?
I currently have the IK20 plugs with the Denso factory gap of .05. Many use the IK22 plus since it is colder but it comes with a bigger gap of .8 according to Denso. So would running the IK22 with a small gap help control KR at WOT?
Old Apr 10, 2014 | 03:19 PM
kylerwho's Avatar
spoon fed
Colder plugs will help to a certain degree.
The fact it doesn't occur in 1 and 2 but it does occur in 3-5 gears probably means there are some higher timing areas that are running too lean. Read your datalog a and add some fuel(until you see 13.5:1) to try and kill the knock. If that doesn't then reduce timing by a degree.
Old Apr 10, 2014 | 05:17 PM
apexanimal's Avatar
^yup
Colder plugs will help... Not 5* worth but they will... Regap accordingly...
Old Apr 10, 2014 | 08:14 PM
^yup
What gap is good for the Fit with Mods?
Old Apr 10, 2014 | 10:29 PM
apexanimal's Avatar
I'm actually not sure... Do some research around here, especially in the threads regarding the ik22 plugs...
Ideally you want the gap to be as wide as possible while still keeping a strong spark...
Old Apr 11, 2014 | 04:56 AM
kylerwho's Avatar
spoon fed
I have seen people run anywhere from .045-.052 gap with the ik22. Im running .05 since that is the manufacturer's recommendation.
Old Apr 19, 2014 | 07:40 PM
Waiting for my plugs to come in this week. Going to try and see if that helps some. I data logged the car a few times to get an idea on where the KR is hitting.
Honestly I have no clue what the hell i'm doing when I try to read the graphs. Is there a "learning to tune for dummies" book out there. I would like to be able to just fine tune work the tuner did on the dyne for me. The shop is cool and willing to fix it but i'd like to learn some of this myself for future tuning.
