Rusty drive axle covers!
Old May 4, 2014 | 08:14 PM
Hondicious's Avatar
I was underneath the car the other day and I noticed that both drive axle covers are very rusty.
Old May 4, 2014 | 11:33 PM
13fit's Avatar
that is just the outside of it. it will not rust apart or anything.
Mine looks the same. I expect my cv shafts to be replaced because of bad bearings FAR before that rust does anything.
Old May 5, 2014 | 12:25 AM
ikutoisahobo's Avatar
Rust like that is not an issue, You'll notice a lot of rusty things down there, like suspension bits and etc, axles. But that's just surface rust and doesn't eat up the metal components.
Sheet metal is affected a lot worse from rust due to its thin characteristics, and rust is able to eat up these parts a lot quickly.
Old May 5, 2014 | 10:22 AM
Hondicious's Avatar
Well that maybe so but it does show you where Honda used cheap steel instead of Aluminum to keeps costs down. A little galvanic corrosion may in evidence where Aluminum and steel meet.
jpcavanaugh
Aug 8, 2017 07:58 PM
howardmitch
Aug 4, 2017 08:02 PM
teamkitty
Nov 15, 2010 09:49 PM
413FIT
Aug 30, 2009 07:57 PM
WaterWatcher
May 4, 2005 11:16 AM
