Starter removal: upper bolt
Old Jun 2, 2014 | 07:24 PM
doctor J's Avatar
Removal of the upper starter bolt is very fun task, especially breaking it loose
I fabricated a "stupid tool" for this purpose and it worked.
The video below is not the actual breaking off moment 9which vas evident by slight click as the bolt began to move.
Old Nov 12, 2016 | 01:52 PM
radioarno's Avatar
doctor J if you're still around, your video is not available, neither on youtube. Can you repost it.
Old Nov 13, 2016 | 08:07 AM
doctor J's Avatar
I deleted this video due to the lack of interest but this is how to do it:
Obtain 14 mm offset wrench and cut it as shown below
Next, get the 45 degree rigid conduit elbow (1/2") and flatten one end to admit the wrench
place wrench on the starter bolt, slip conduit on it and insert a round wrecking bar into other end (between radiator and engine)
Push on the bar toward engine
This should crack the bolt loose.
Attached Thumbnails Starter removal: upper bolt-80-dsc02170_c436846dc9465dbcb332de9ab250794efec34160.jpg   Starter removal: upper bolt-80-5701352b_2540_4d09_9b88_368a8cb7488e_1000_9a946cd6f6dfa541aac88463ef9ec5e4e1ac5e10.jpg
Old Nov 13, 2016 | 02:50 PM
radioarno's Avatar
fantastic. thanks a lot. Going to replace my starter soon.
Old Jan 10, 2021 | 12:17 AM
FTBT's Avatar
Old Jan 11, 2021 | 02:44 PM
doctor J's Avatar
Originally Posted by FTBT
Second generation is different animal and has much better access to the starter
Old Jan 11, 2021 | 03:54 PM
FTBT's Avatar
Interesting. Please post photo of amount of access when coolant overflow tank removed if you can for 1st gen.
It's funny but my first inclination was to gin up a special tool by potentially welding something up using a "spare" 14mm socket or box wrench but I took a look at the length of box/open end wrench and decided to give that a try first. I've got a tool box drawer full of specially-fabricated tools that I've used over the years for which I can not even remember application in some cases (but still I keep 'em all just in case). Obviously, for most people it would be best if fabrication of "special tool" would not be required. Another thought: how difficult would it be to remove fan assembly to gain better access?
Old Jan 15, 2021 | 10:27 PM
okey0's Avatar
This is how I got the top bolt, from ABOVE. 1/2" ratchet, 9" extention, flex coupler, 1/2 to 3/8 reducer, 6" extention, flex coupler, socket. Slipped it down between engine and radiator. The 2 flex couplers snaked it around the starter and it actually came out easier than expected.
PT Aleco
Sep 28, 2025 01:33 AM
MyFitment
Aug 2, 2020 03:29 PM
doctor J
Dec 14, 2018 11:16 AM
Rrff1954
Aug 26, 2018 08:17 AM
mmdir2002@yahoo.co.uk
May 4, 2005 11:16 AM
