New Fit owner
Old Aug 4, 2014 | 10:07 AM
F1Flagger's Avatar
New Fit owner
Hello All.
I am about to purchase a 2007 Fit Sport.
139,000 on the clock. Dealer had the timing chain and tensioner adjusted, along with valves. A/C condenser replaced, new tires and state inspection done.
Once I take possession I will be checking on plugs to see if they need to be replace along with air filter, and most likely trans fluid.
Anything else I need to look for??
Looks like it is going to make a great commuter car!
Old Aug 4, 2014 | 11:36 AM
GinoLicious's Avatar
Welcome to the boards. I've been a fit owner since 2007. I have 165,000km on my GD3. Original owner.
What I would check/ replace are:
Oil - replace
Plugs - replace
Tranny fluid - replace
Brakes - Inspect
End links - inspect
Ball joints - inspect
Bushings - inspect.
Old Aug 4, 2014 | 01:49 PM
F1Flagger's Avatar
Oil - replace
Plugs - replace
Brakes - Inspect
End links - inspect
Bushings - inspect.
Thanks for that.
Oil was changed.
Brakes, ball joints and those items fall under the State inspection which was done in june.
Plugs and Trans Fluid I planned on doing.
Thank you for reply!!
Old Aug 4, 2014 | 01:53 PM
I'm assuming tie rods fall under the state inflection as well? I'm in Canada so yeah always different. What do you plan on using for tranny fluid? I always suggest GM synchromesh. I also forgot, cabin air filter. Get that shit running clean air.
Old Aug 4, 2014 | 05:02 PM
derykisonder's Avatar
The most important things that you didn't mention are these:
Valve adjustment should be your co-number 1 priority
Ignition coils is the 2nd co-number 1 priority
Old Aug 4, 2014 | 05:52 PM
Valve adjustment I totally left out. That he may not want to do himself. A little bit of work, depending how handy with tools. I myself need to do one. Coil packs meh. I'm not misfiring or stuttering after 165,000km.
Old Aug 4, 2014 | 10:05 PM
Valve adjustment you can definitely do it on your own. There's a guide on here. It depends how aggressive you drive. My coilpacks are running great
Old Aug 5, 2014 | 09:06 AM
F1Flagger's Avatar
Thanks
Yes the valves were done along with adjusting the chain and tensioner.
Plan to do plugs then coils.
How many qts to do trans?
I assume it is a partial drain like the Acura's I have owned.
Trans fluid will be Honda factory. It is what I have always used on my Acuras
skibum07Sport
Aug 23, 2018 11:12 PM
hawkfitohio
May 28, 2018 09:58 AM
bikerdrumr
Dec 3, 2017 09:41 AM
User1
Sep 29, 2017 11:32 PM
F.IT
May 20, 2008 07:53 PM
