driver side (left side) cowl removal?
Old Nov 9, 2014 | 06:23 PM
s0x's Avatar
s0x
does anyone know how to take the half of the cowl off thats on the driver side without damaging anything? trying to install my T1R hood damper and can't get to the back bolt on the hood hinge.
Old Nov 9, 2014 | 09:25 PM
derykisonder's Avatar
It probably won't be the same as the ge8 but I found this.
https://www.fitfreak.net/forums/2nd-...tml#post988433
Old Nov 9, 2014 | 09:30 PM
MTLian's Avatar
It's stuck on with a kind of double sided tape. Just use some good ole elbow persuasion (yanking) and it should come off easily. I even reattached it by simply reusing the same adhesive strip.
Old Nov 10, 2014 | 07:32 AM
DWils's Avatar
When I installed mine I didn't need to take off the entire cowl, just the corner plastic/rubber piece on the bottom of the windshield. It has little rubber nipples that will break off, so be careful. I also couldn't get them back in the little holes when I was done so I just left the piece there for a few years. When I got my windshield replaced the person snapped that piece back in for me. Good luck!
Old Nov 10, 2014 | 02:12 PM
s0x's Avatar
s0x
How were you able to reach the back bolt? Just a regular closed end wrench? I can't get in there with a socket
Old Nov 10, 2014 | 08:47 PM
DWils's Avatar
I can't remember. Do you have a socket extender? I might have used one of those or one of those things that has a flexible angle on it. It didn't come with instructions?
Old Nov 10, 2014 | 09:04 PM
DWils's Avatar
Try these threads for more information: https://www.fitfreak.net/forums/1st-...pers-help.html, https://www.fitfreak.net/forums/1st-...tall-help.html, https://www.fitfreak.net/forums/gaug...od-damper.html. Those might help. I swear mine either came with instructions or I lucked out and found out how to do it somewhere on here. Heaven knows I can't do stuff by myself which is why I'm thankful to have found this forum because everything I want to do has already been done.
Old Nov 11, 2014 | 05:43 AM
s0x's Avatar
s0x
thanks man ill look over these. as far as the cowl goes the moment i removed the wiper arms it just slid right off but now I'm having trouble getting the hood closed with the t1r kit installed so ill do some reading! you're awesome.. moral of the story... REMOVE THE WIPER ARMS the rest is simple.
Old Nov 11, 2014 | 06:02 AM
DWils's Avatar
Will it at least close a little, or is the hood stuck all the way open? If it will close most of the way but won't latch you may have to tweak the rubber nipples on the crossframe to allow the hood to close all the way. I'm glad you finally got it. Now that you mention it, taking off the wipers sounds faintly similar to what I had to do when I installed my damper. Crap, I'll still pop my hood sometimes just to play with the damper!
Old Nov 12, 2014 | 05:46 AM
s0x's Avatar
s0x
it will latch but it won't lock down. like it goes to the first step but not the lock step. super annoying what rubber nipples do you speak of good sir?
Old Nov 12, 2014 | 07:12 AM
DWils's Avatar
They're black/dark-colored pieces of hard rubber that have little slits in them. They are about the size of a US nickel on the bottom and are somewhat conical. Look on the top part of the frame that connects the left fender and the right fender together (above your AC condensor and radiator) and they should be near the fenders. I would post a picture of what they look like but I'm not near my Fit right now and I can't upload pictures to FitFreak because I don't have a third-party photo hosting account. The rubber things are about 3/4 of an inch tall and can be twisted to raise/lower them to allow the hood to close. Did you have any problems before the damper install?
Old Nov 12, 2014 | 02:21 PM
s0x's Avatar
s0x
aaaaaaaaah i didn't have any problems before but I'm also pretty sure i don't have these pieces on my car. i have a JDM front end and the parts just came bare no trim..
UPDATE!
i do indeed have them I've just never noticed them before lol
Old Nov 13, 2014 | 04:10 AM
DWils's Avatar
So does it fully close now after the update?!
Old Nov 13, 2014 | 03:25 PM
s0x's Avatar
s0x
i actually don't know i got frustrated and took it off hahaha but i will tinker with it again soon. i think honestly it might just be too much resistance for such a light hood? not sure.
Old Nov 13, 2014 | 10:46 PM
DWils's Avatar
Previc93 has a carbon fiber hood and the damper, so I know the combination works. If you leave the hinge on but remove the damper rod does the hood still not close all the way? Dumb question, but I have to ask because sometimes we overlook the simplest things, but did you leave any tools in the engine bay that would prohibit the hood from fully closing?
Old Nov 15, 2014 | 04:42 AM
s0x's Avatar
s0x
not a dumb question. disconnected it does close yes.
Old Nov 16, 2014 | 01:35 AM
DWils's Avatar
Did you attach it like in the bottom photograph on this page: Type One Racing :: Engine :: Fit/Jazz (GD3/4) :: T1R Engine Hood Damper - Honda Fit 07-08 GD3?
Old Nov 16, 2014 | 03:29 PM
DWils's Avatar
I got it! I was out in the garage playing with my because damper and it came to me. Put your damper back on and slowly close the hood while you look underneath the hood at the damper rod. Is it hitting on the front (part closest to bumper) part of your engine fuse box? That may be the reason why your hood will not fully close with the damper rod on it. What I did to remedy that problem that I had was I put about .25-.5 inches of washers under the bolt that attaches to the headlight. That lifts the front end up just enough to clear the fuse box and will let the hood close without putting pressure on the fuse box.
JawnStockedIn
Nov 10, 2018 04:51 AM
WyldeFit
May 9, 2018 12:06 PM
DaytonaFit
Mar 18, 2018 10:44 PM
aelk799
Mar 18, 2018 05:45 PM
Bowkr
Dec 28, 2009 03:09 PM
