hid problem/bi-xenon..
Old Feb 21, 2015 | 12:03 AM
ALLDAYKK's Avatar
So I installed a bi-xenon kit in my GD and it is pretty awesome, but when I turn on or flash my high beams, it stays in high beam. I can't get it back to low beams unless I keep flickering on and off. And I already know one solution to this which is not to use the high beams ever ha. But just want to know why that happens and if it's a comifn problem?
Old Feb 21, 2015 | 04:11 AM
Goobers's Avatar
Issue probably has more to do with the HID kit than the Fit itself. This is usually the result of a sticking solenoid.
Old Feb 21, 2015 | 04:19 AM
Desmond Lamar MacRae's Avatar
My kit the right bright wouldnt work. The company sent me a new wiring harness and ballast just in case. The fuse in the wiring harness was blown so i swapped that first and everything worked. And for the record this was a 80.00 kit off amazon with 3yr warranty. Customer service was great.
Agelee
Nov 11, 2011 12:49 PM
phuccer
17
Jul 16, 2010 04:36 PM
stnl619
Dec 24, 2009 12:40 PM
kodo
19
Jan 24, 2009 12:49 PM
FITtin'
Dec 9, 2008 04:29 PM
