Screeching noise on front right wheel area
Old Mar 21, 2015 | 07:12 PM
Phamtastic's Avatar
So today i noticed that my GD3 2008 honda fit make screeching noise ( like someone is dragging metal underneath my car ) on the right front wheel area.
Not sure when it actually happen ( my friend noticed it last week but i though he was fucking with me since i couldn't replicating it ). Today after braking hard on the autobahn ( at around 70 mph, to the point where i can feel the ABS kick in ) and as i was driving up the side of a mountain through a winding road, i noticed the screeching noise. The noise doesn't seem to be there when i'm driving fast, only on around 1st or 2nd gear.
After some google-ing, i did the following step.
1. Remove the front right wheel and check for stuck rock behind the brake caliper ( the little metal shield behind the brake rotor ). I do noticed rust on the caliper.
2. topping brake fluid.
3. put it in reverse and reverse it hard.
4. go over a speed bump hard
5. hard braking to the point where i can feel the Anti-lock kick in.
after some further troubleshooting, these are the following things that i did and what i think cause the screeching sound.
1. if i drive around in a left circle, the noise doesn't seem to happen. Only on right turn or sometime randomly as i'm driving straight ( again only at low speed)
2. If i tap the brake slightly, the screeching noise go away.
3. Car doesn't pull to the right at all if i let my hand off the wheel ( at both slow or high speed )
4. I have my friend stepping on the gas while the engine is in neutral, i put my ear right next to the engine and i don't hear any screeching noise.
What the f*** is going on ? i just bought the car used a few weeks back ( according to the owner, she hasn't change anything yet beside oil and transmission fluid.
Old Mar 22, 2015 | 01:31 AM
xxryu139xx's Avatar
did u check the brake pad? its probably worn out and telling u to replace it via said "screeching" sound.
Old Mar 22, 2015 | 10:47 AM
Phamtastic's Avatar
I didn't check the brake pads ( i'm fairly new to owning/maintaining my own car ).
Now that i think about it, the brake pads probably needs a new replacement.
Old Mar 22, 2015 | 11:06 AM
xxryu139xx's Avatar
i hope to God that she has changed the brakes at least once since 2008.
Old Mar 30, 2015 | 04:25 PM
Phamtastic's Avatar
She didn't. The brake pads is worn down to about 1/5 off what the new one is. Changed it and the noise went away. It brake in an amazingly shorter distance too.
Old Apr 6, 2015 | 02:22 PM
F-it good's Avatar
Make sure you bleed the brake lines, feels a lot better
Old Apr 6, 2015 | 10:21 PM
solbrothers's Avatar
Why? I have 65k miles on my 2007 Fit and replaced my brake pads and rotors on the front last summer.
Phamtastic
Mar 30, 2015 04:51 PM
Lobo1101
Jun 3, 2014 06:02 PM
msoulier
Jul 22, 2011 11:22 AM
OEMfit
Dec 27, 2008 06:38 PM
dgff
Jun 12, 2008 09:43 PM
