belt squeal when hot
Old Aug 12, 2015 | 04:39 AM
craigquakertown's Avatar
Angry belt squeal when hot
my belt squeels when in hot weather and I have no idea what it could be when I turn on ac when warm it gets louder any ideas would help its driving me crazy
Old Aug 12, 2015 | 11:48 AM
Rob22315's Avatar
Either a bearing is going bad, or you need a new belt. A new belt is around $30 and is a fairly easy DIY to do the install. If one of your rotating parts is going bad, you'll have to figure out which one to know how much it would cost to repair.
As a stop-gap, you could try to increase the tension on the existing belt by tightening it. Belt tension is adjusted by moving the alternator. The best way to do that is to use the procedure in the serpentine belt DIY here:
https://www.fitfreak.net/forums/fit-...tine-belt.html
Old Aug 12, 2015 | 03:55 PM
Today I didn't even hear it much on the car thanks I'm gonna do the belt first I am almost at that cycle anyway so it's kinda due
Old Aug 13, 2015 | 08:04 AM
Carbuff2's Avatar
^^^ Good move. Once a rubber belt starts to squeal, the surface become glazed, making it slippery.
Not wise to try to compensate with more tension....
grommet
Apr 27, 2026 09:57 PM
mikejet
Sep 22, 2021 11:04 PM
Marrk
Apr 11, 2017 10:52 PM
hazzard
Nov 20, 2013 01:38 AM
