Check engine light on, no code from OBD2 scan, now what?
Old Aug 20, 2015 | 02:06 AM
Rob22315's Avatar
I used Torque to check the codes and do a full readout on the engine parameters. No codes but a few of the parameters were out of whack. Any suggestions for where to start?
Car seems to run fine for a car with 103k miles on it. I did the valve regap two weeks ago but not much else recently.
Old Aug 20, 2015 | 09:52 AM
can u clear it? see if it comes back.
Old Aug 20, 2015 | 11:06 AM
Rob22315's Avatar
I did a code clear but the light stayed on. Any chance this si an indication that it's time to change the coolant?
Old Aug 20, 2015 | 11:33 AM
I doubt there is an ses for coolant change interval.
Old Aug 20, 2015 | 12:52 PM
Rob22315's Avatar
The manual says there is but it might be a B4 rather than the engine light.v it's supposed to come on around 120k miles
Old Aug 28, 2015 | 09:35 PM
Rob22315's Avatar
The light went out. I'm guessing one of our drivers didn't get the gas cap on all the way.
Old Aug 30, 2015 | 08:29 PM
Carbuff2's Avatar
Once I forgot to reconnect the IAT sensor on my CR-V after cleaning the throttle body. I couldn't turn off the CEL. (But the code went away) It finally extinguished on it's own after a number of drive cycles.
PhilRai
Dec 6, 2016 07:12 PM
payluder
Jun 28, 2016 01:06 PM
kitenok
Dec 10, 2015 07:28 PM
SevereService
Sep 7, 2014 03:14 PM
bjvalencia
Oct 11, 2011 03:16 AM
