using A/C recycles radio
Old Jul 13, 2016 | 11:05 AM
ghostagent's Avatar
think this is a fairly new problem. My 08 fit is now having periodic radio resets when I'm using A/C and the compressor is coming on. I also see the flicker of the headlamps as the A/C compressor kicks in.
Am I looking at an alternator replacement soon or bigger problem??? I'm considering trading in for a 2016/2017 so I'd like to avoid a costly fix right before if possible.
Old Jul 14, 2016 | 07:30 AM
Carbuff2's Avatar
I'd check the tiny battery first. A weak battery could let the voltage drop enough under load to where the radio needs a reset.
Besides the AC compressor, the system also turns on the radiator fans. So this is one of the more power-demanding systems in the car.
Lew
May 4, 2019 08:47 PM
Duhvidx
Sep 5, 2013 01:30 AM
LoveMyFit49
Mar 6, 2013 06:58 PM
kentris
Aug 14, 2006 12:48 AM
Jon Waisnor
May 4, 2005 11:16 AM
